Extract first line from a description field
manolo7
Post by manolo7 »
In the past I used the DESCRIPTION field to collect "Languages", "Country" and "Description". The data was stored in this field with the HTML tag I need. Now I organize the catalog in a different way and I need to move "Languages" and "Country" from this field to another, leaving the DESCRIPTION field with only original "Description" data.
My DESCRIPTION field looks like this:
<h3>Languages: </h3>English <h3>Country: </h3>USA
<h3>Description:</h3>Lorem ipsum dolor...
First line have a variable length, but always end with CR/LF followed by the "<h3>Description: </h3>" and can be easily extracted, but I don't know the script functions/procedures that can do it.
Does anybody know how can be done this?
manolo7
Post by manolo7 »
Here is the solution for extracting the first line:
s, t: string;
w: integer;
s := GetField(FieldDescription);
w := Pos('<h3>Description',s);
t := copy(s, 1, w-3);
SetField(FieldLanguages, t);
Another way would be using StringUtils1 and TextBefore function:
  StringUtils1;
  value: string;
  value := GetField(FieldDescription);
  value := TextBefore(value, #13#10, '');
  SetField(FieldLanguages, value);
  SetField(fieldDescription, RemainingText);
Using variable RemainingText it finally will delete language and country from description field.
