no download of filmdetails
daniel
Post by daniel »
When I add a new film and want to get the information a message appears :
HTTP/1.1 404 not found
also no information about the film ,actors,producer etc...
downloaded the latest version and trouble started??
any ideas and thanks
greetingd
Latest program version might come without latest script updates, as scripts have to be updated whenever a website's source code changes.
Try downloading latest script version from http://update.antp.be/amc/scripts/ or use script [UPDATE SCRIPTS]. If it still does not work you should report the broken script on scripts section of this forum, maybe someone can update it.
daniel
thank you
Post by daniel »
Thank you bad4u for helping out.
followed your advice with good result
greetings
