IMDb script patch where TranslatedTitle is always equal to OriginalTitle
fluxtion2
Post by fluxtion2 »
It allows you to do cool things with the title template like this:
[TranslatedTitle] ([OriginalTitle], [Year])
That then look the same in your checklist, regardless of whether the movie are in foreign languages or not:
I'm working on a way to integrate it into the default IMDb script using script settings, but at the moment, you can apply this patch (context diff) file:
https://pastebin.com/h9sPBbAL
I'm also working on improving the IMDb script's handling of TV shows and individual episodes. But I just thought I'd chuck this out there in case it helped anyone else trying to create cool and advanced title templates.
Re: IMDb script patch where TranslatedTitle is always equal to OriginalTitle
You are welcome to improve the IMDb script if you can :)
There is no one working on it "officially" currently, but of course it is possible that somebody is working on it without saying it first :D
