Removing scripts from scrips list
Nolle
Post by Nolle »
Hello,
Is there a way to remove scripts from the scripts-list ? Should be easier to work if there's only the scripts you needed...
Thx in advance,
Nolle
Either use the language filter, or simply delete the corresponding files. But delete only .ifs files; the .pas files are themselves used by various scripts.
Nolle
Post by Nolle »
Thx !
Deleting the .IFS-files worked fine ! Now I have only the scripts I need in the list and that's much easier to work with :)
Great program !
