I just downloaded the info for the 2024 series Landman. I noticed that's the second show I downloaded info for today that had no directors info, no producer or writer info, and no date. Is there a problem with the script or is there no info for download in those categories?
I've just checked back and I have at least a dozen shows going back a couple of months that are also missing that info? I am using the IMDB script. I just updated every single script and restarted, but still no info showing.
Not all information being downloaded?
Re: Not all information being downloaded?
I'm not sure that the IMDb script is really compatible with series retrieval.
It is probably possible to update the script to improve compatibility with these, but I don't really have time for that (the focus was rather made on movies) so it depends if some other user has time and knowledge for improving it.
boristhecat
You know, after all these years and hundreds of TV shows, I never even noticed. I've now looked back at shows from 2000 and sure enough, no director etc. My apologies, I'd never noticed that before and thought it was a fault. I just added another film and that worked fine.
It's no bother to manually add to TV shows, thanks for the reply.
