IAFD 403 error
IAFD 403 error
Hello,
I have been getting 403 forbidden error with the IAFD script, changing the User Agent in [GetScriptWin] is not helping, anyone else with this issue?
Help!!
Help!!
Re: IAFD 403 error
I understand this is because they have installed an anti-scraping software or something limiting this but any other workaround?
Anyone has an example of GetPage5 changing the user agent? is it possible?
Thank you!
Thank you!
Re: IAFD 403 error
maybe you are right in pointing that error but il should be helpfully to say what movie you are searching.
https://www.netsons.com/manage/knowledg ... KwZISrLAmw
Re: IAFD 403 error
Doesn't matter much which, it doesn't work with any movie, it happens on "GetPage" function.
I have tried with movies that used to work, still the same.
Re: IAFD 403 error
I'm sorry, I tried, but I don't know how to help you.robbdj75 wrote: 2025-02-11 18:38:40 Doesn't matter much which, it doesn't work with any movie, it happens on "GetPage" function.
Re: IAFD 403 error
At some point if sites block the retrieval of their data, I can't do anything against it, it is their right to refuse it
Re: IAFD 403 error
antp wrote: 2025-02-17 18:28:53 At some point if sites block the retrieval of their data, I can't do anything against it, it is their right to refuse it![]()
Re: IAFD 403 error
It could be a problem about user gent, isnt'it?antp wrote: 2025-02-17 18:28:53 At some point if sites block the retrieval of their data, I can't do anything against it, it is their right to refuse it![]()
Re: IAFD 403 error
User agent is "Mozilla/5.0 (compatible; Ant Movie Catalog)", and browsing the site with that user agent set in the browser seems to work.
So it is probably a more generic anti-bot system that they use.
And it also means that just changing the user agent will not be enough, as said in the first post...
Re: IAFD 403 error
I saw it... sorry, I forgot to say that in robots.txt there is a stop to every spider.antp wrote: 2025-02-20 18:09:06 ... just changing the user agent will not be enough, as said in the first post...
May be that robots.txt could be bypassed?
This is: https://www.iafd.com/robots.txt
- # No sucking our data. You're welcome to use our homepage as a reference
# and our glossary and such... but no data...
# read our TOS for more details http://www.iafd.com/
User-agent: *
Disallow: /*-responsive.asp
Disallow: /*-responsive.rme
Disallow: /classified/
Disallow: /scripts/
Disallow: /java/
Disallow: /snitzf/
Disallow: /snitzfor/
Disallow: /stats/
Disallow: /shopclick.asp
Disallow: /person.asp
Disallow: /title.asp
Disallow: /banman/
Disallow: /*Zuleidy*
Disallow: /*zuleidy*
Disallow: /*jhennifers*
Disallow: /*-Lupe*
Disallow: /*/Lupe*
Disallow: /*-lupe*
Disallow: /*/lupe*
Disallow: /*jkenney*
Disallow: /*angelika_cz*
Disallow: /buymovie.rme/
Disallow: /reviewjump.rme/
Disallow: /galleryclick
Disallow: /random
Disallow: /*joaosei*
User-agent: CCBot
Disallow: /
User-agent: Fasterfox
Disallow: /
user-agent: AhrefsBot
disallow: /
# No sucking our stuff
User-agent: Teleport Pro*
Disallow: /
User-agent: Wget*
Disallow: /
sitemap: https://www.iafd.com/sitemap-master.xml
Re: IAFD 403 error
The robots.txt is just an indication for robots so they know what they can browse or not, but it is up to each of them to follow it or not.
Re: IAFD 403 error
It was nice while it worked, I might add that thanks for writing the script and the support
What I will personally going to do is to create a Power Automate script to download the HTMLs I need and then run the script to read the local files. I will create a new version. Let me know if you want to have that script.
The only manual thing to do will be copying each URL, still less work than copying and pasting each field
Re: IAFD 403 error
I think it should be useful.robbdj75 wrote: 2025-04-23 20:42:50 ... Let me know if you want to have that script.
The only manual thing to do will be copying each URL, still less work than copying and pasting each field![]()
