[HELP] Exporting Pictures
thefunwarden
Post by thefunwarden »
This has probably been asked before but i can't find a clear answer. Is there anyway that AMC can export pictures into a sub folder when exporting to HTML, XML etc etc. it was one of the feature i like about GCStar.
well it was at least asked by you in that other topic at the same time :D
viewtopic.php?p=28136#28136
