HELP with twink template and firefox
thefunwarden
Post by thefunwarden »
hi I'm new to the AMC and was wondering if someone could help me.
The problem i am having is that when I export my database using the twink template everything displays right in Firefox but the numbers and letters you click on to move to different sections doesn't work. but it does work if i open it in internet explorer. is there anything i can change in the HTML code to make it work with Firefox.
spiderman
Post by spiderman »
the twink template doesn't work in FF.
viewtopic.php?t=4201 is an adaption from it
thefunwarden
thanks for the info, it's a shame it doesn't work because its a nice simple template, i do have another question which i will post somewhere else on the forum but i'll put it here to. when exporting to HTML and i think all the other options, is there a way of exporting the pictures into a sub folder instead of the main folder
no, sorry, the export is rather old (there since early versions) and was never much improved, so it is somewhat limited.
