Help me Installing Version 4.2.3.3
masterchipo
Post by masterchipo »
I have installed the version of the title 4.2.3.3 in Program Files (x86)
Imported from virtual store or from Program Files (x86) which also have the catalog saved there and I can't save the new catalog, it asks me to give it another name. I send you a screenshot
https://i.imgur.com/J3hvOSO.jpeg
I can't save the catalog after reloading with the installation of the new version.
The catalog hasn't worked for several days, but I really don't know how to do this.
PD Si alguien de habla hispana me puede explicar esto, agradeceré infinitamente
Re: Help me Installing Version 4.2.3.3
It is better to put it in the Documents folder (or any folder where your Windows account has normal writing rights).
Have you tried to copy the file from Program Files or from VirtualStore to another folder?
masterchipo
Friend, yes I have tried, but I can't save it.
First step: import catalog (so far so good). Second step: Once imported, it loads with the list of movies that I already had saved in virtual store or as you say a copy in documents... The problem arises when once loaded, I can't save that catalog, I don't have the option to save. Below there are only three options, import, cancel and help. None of them is save. And on the top left, there are four icons. The first is a folder that when you click on it indicates up, the second is a diskette that I imagine means save, the third is a window that has two arrows and the fourth is the one that has a window to expand or I don't know what.
I'm a donkey and I stop at the first step which is to load from the place where the last catalog is saved. That's as far as I go. I don't know the next step, that is, save.
What is wrong with the program that doesn't work?
We have been unable to get the catalog to work for many days.
I tried different scripts and none of them work.
It doesn't work in all languages?
Any idea what it is?
It really strikes me that very few users have bothered. For me, Ant Movie Catalog is part of my life.
There are two programs that I depend on, and they are the oldest and so difficult for me to configure, every time I make a change on my PC, one is this one, the other is Subtitle Work Shop
Gracias amigo
masterchipo wrote: 2025-02-03 15:49:18 First step: import catalog (so far so good). Second step: Once imported, it loads with the list of movies that I already had saved in virtual store or as you say a copy in documents... The problem arises when once loaded, I can't save that catalog, I don't have the option to save. Below there are only three options, import, cancel and help. None of them is save.
But so you are still in the Import window? You just loaded the movies in the preview list, allowing to configure columns / field mapping. Once all is right, you click the "Import" button to actually do the import in the current catalog in the main window, and there you can save the catalog using the Save icon of the main window.
The small save icon in the import window is to save the column/fields association in case you have to import multiple catalogs with the same custom mapping.
You can find more info about the import process in the Help document.
By the way, why do you need to import in the first place? This function is mostly made to combine several catalogs into one.
It does not really have a sense to import your catalog into a empty new one... why not simply open your catalog rather than importing it?
