How can I rename unicode to ansi ?
geechunp
Post by geechunp »
How ????
It is not really possible in current version, but it would be a good idea to add it... So maybe for a future version.
In the meantime, there is a solution, but not especially easy: using the "multiple string replacement" feature you can define what has to be replaced by what, but for Hangeul (to take your example) there would already be lots of combination to enter to have all the cases...
