Filmaffinity
raulsara01
Filmaffinity
Post by raulsara01 »
Hello, it gives me a problem by accessing the Filmaffinity script. It is possible that there has been a change on the web?
Re: Filmaffinity
I suppose that the site changed something indeed.
Someone will have to investigate and fix the script...
PACOIRIPO
Re: Filmaffinity
Post by PACOIRIPO »
Hello. Indeed, it does not link to the website. Let's see if someone with enough knowledge fixes it. Thank you very much for maintaining the best movie catalogue, Regards.
pakovilla
Re: Filmaffinity
Post by pakovilla »
Yes please, let's see if someone in control can take a look at the script and fix it. Thank you so much!
carlesaran
Re: Filmaffinity
Post by carlesaran »
Hello: It seems that the breakdown is more serious than it seemed. It has 900 visits and still no one has been able to fix it, let's hope someone can solve it.
Thank you and best regards.
yaya2023
Re: Filmaffinity
Post by yaya2023 »
When running it, if instead of putting the name of the movie/series, the complete web address of the series or movie is placed in Filmaffinity, the script recovers all the information...
I don't know how to modify the script, I mention what I saw in case someone can fix it. Thanks
AUPAKEPA
Re: Filmaffinity
Post by AUPAKEPA »
Efectivamente, hay algun problema. Con la ruta completa funciona. Pero con la busqueda normal da la sensacion que conecta, porque marca que descarga bites pero no muestra ningun resultado. Yo soy incapaz de solucionarlo, no conozco el lenguaje ni la estructura.
Taino75
Re: Filmaffinity
Post by Taino75 »
Si conseguís solucionarlo, avisad, por favor. Es el script que utilizo yo.
Gracias.
Radagast
Re: Filmaffinity
Post by Radagast »
Algo han cambiado en la pagina de búsqueda que el script no puede recuperar la información y pasa directamente a la pagina de información de la película con los datos en blanco. Esperemos que alguien con conocimientos lo pueda solucionar.
Something have changed on the search page that the script can't recover the information and goes directly to the film's information page with the empty data. Hopefully someone with knowledge can solve it.
Re: Filmaffinity
yaya2023 wrote: 2025-01-31 14:44:27 When running it, if instead of putting the name of the movie/series, the complete web address of the series or movie is placed in Filmaffinity, the script recovers all the information...
That's good news, it probably means that only little change is needed.
At least there is a workaround until it is fixed.
I'll try to take some time for it next week.
Re: Filmaffinity
I'm working on the problem and I hope to get the aim in a few days. ;)
PACOIRIPO
Re: Filmaffinity
Post by PACOIRIPO »
Thank you so much.
Radagast
Re: Filmaffinity
Post by Radagast »
@antp and @fulvio53s03
Thank you very much for your help guys
weyden
Re: Filmaffinity
Post by weyden »
The filmaffinity script doesn't work for me either.
But with the solution, and until it is fixed, from user yaya2023, it is working for now.
Ant movie is the best film cataloger there is. Many thanks to whoever makes it possible!!!
Greetings from Spain
A mi tampoco me funciona el script de filmaffinity.
Pero con la solución, y hasta que se arregle, del usuario yaya2023, de momento va funcionando.
Ant movie es el mejor catalogador de cine que hay. Muchas gracias a quien lo hace posible!!!
Saludos desde España
masterchipo
Re: Filmaffinity
Post by masterchipo »
Amigo, @yaya2023, lo podrías explicar en español y con un ejemplo concreto.
Soy un burro en esto y no entiendo nada
Gracias (escribo en español porque en primer lugar estamos en Filmaffinity una página en español y segundo, me expreso mejor que con un traductor)
PACOIRIPO
Re: Filmaffinity
Post by PACOIRIPO »
Te respondo en castellano:
Te vas a filmaffinity y buscas la pelicula en cuestion y copias la url.
Pegas la url en el campo titulo original y con F6 ejecuta el script filmaffinity.
Así, sí encuentra los datos.
Espero que me haya explicado bien y lo hayas entendido.
Saludos.
masterchipo
Re: Filmaffinity
PACOIRIPO wrote: 2025-02-03 19:13:35 Te respondo en castellano:
Saludos.
Querido Paco, funcionó.
Si seré bruto, no?
Era tan simple como ubicar la url donde va el título en el catálogo.
Yo ponía la url en el lugar que va.
Mil gracias
yaya2023
Re: Filmaffinity
Post by yaya2023 »
Thank you so much for taking care of it!!
Re: Filmaffinity
Prueba esto y cuéntame...
Try this and let me know.
https://forum.antp.be/phpbb3/viewtopic.php?t=43129
:innocent:
Taino75
Re: Filmaffinity
Post by Taino75 »
fulvio53s03 wrote: 2025-02-04 18:03:04 Prueba esto y cuéntame...
:innocent:
Than you... ¡It works correctily!
GRACIAS
Locked
