Can you convert the comment field to a TstringList with the built in functions in the Scripting engine?
I'm trying to navigate through a list of Extra fields that i manage in the comments field and i haven't been able to figure out how to convert the comment field into a tstringlist it simply deletes formating when i copy it over to any variable, causing an error when i try to use the TstringList to navigate through it
Comment Field With Linebreaks to TStringList?
Re: Comment Field With Linebreaks to TStringList?
Sure.Nicezia wrote:Can you convert the comment field to a TstringList with the built in functions in the Scripting engine?
list := TStringList.Create;
list.text := GetField(fieldComments);
