$$ITEM_CHECKED ????
scottdw
$$ITEM_CHECKED ????
Post by scottdw »
Is $$ITEM_CHECKED available to be used??? I can get all of the other variables to work but is there one for the movie being checked or not?
Thanks,
Scott
With that variable it puts "x" if the movie is checked, else nothing.
