Edit in Grid Mode v3.3.0
my question is this
how can i edit the movie details when i'm in Grid mode
since it isn't impossible to order the movies in the defult mode in the program other than number and title
is there a way that i will press in grid mode on a certain field and i could edit it ? or i need to change modes ....cos when i change modes i loose the movie which was selected and i'm back to the start of the list :(
i'll explain why it is needed to edit each field in the grid mode
lets say you import with the imdb script ..now we all have forigen movies which the soundtrack is in English ...but the title at IMDB is in forigen language and the language field is imported as well according to the title language ...there are a lot chinease and westerns (which were made in italy) that are known in their english titles and have english sound but ... imdb lists them in the original language but most of us want the english title as well
there are many more examples why there is a need to edit in grid mode...
i also suggest is to modify the script to check if the language is different than english then to inport the US title as well and put it in the translated title or import the original title to the translated title field and put the english title in the original title field.
i hope i didn't give you a headake :hihi:
Edit in grid mode is not possible currently (I would have done it if it was easy to do ;)).
I will add this feature probably when I'll use another component to display the movie list.
For the problem that you have with the sort, you can use the "Group by" feature, in the "Tools" menu ("Group by Language").
For the script, I know that I have to add that. I'll do it some day, when I have time :/
