Compile for MacOSX
approved101
Compile for MacOSX
Post by approved101 »
Can I compile the SOURCE for MacOSX??? How????
Thks n brgds
No, that's not possible.
There is no Delphi compiler for MacOSX, or at least none with full support of Borland's VCL Libraries.
approved101
:hum: it's a pitty, there isn't any software like Ant Movie for MacOSX. Then I will make a program very easy to catalog my films.
One question only, Can I import the script that search films' information in internet to XCode?? Where is that script located in yr source data????
The scripts are script, their purpose is to be independant from AMC's code :D
These are just using a language similar to Delphi/Pascal. So maybe they could be used in any Pascal compiler with little changes, but Xcode being based on C and/or C++ from what I see, it will not be possible to "import" them so easily.
As it doesn't make sense to reinvent the wheel, you could try gcstar ( http://wiki.gcstar.org/en/install_macos ). It is free open source software, too, and was mainly build for linux, but can be installed on MacOSX. It can import your AMC catalog and has a script system, too (but uses another programming language).
I guess it's ok to link it here, as they link to AMC website as an alternative, too. Else it can be deleted ;)
Even links to competitors are ok; I would not mind if people chose something else rather than AMC, as I do not try to sell anything :D
approved101
Ant, I like your program but I use MacOSX ...
Thks for the link ... I already installed it ... it's ok :-)
