Field for 'Writer' (IMDb)
windozer
Post by windozer »
I really miss the field for 'Writer'. Instead, it places the writer in the 'Producer' field.
There is an script option "Producer" for IMDB script. Set it ot "1" and will import producers instead of writers; import needs more time and traffic then, as an additional page has to be loaded. Writers will not be imported then.
Note: You find the script options on the right side of the scripting window.
