change linebreaks
jan_hut
change linebreaks
Post by jan_hut »
In preferences --> Export
the changing of linebreaks doesn't work. you can change it but if you go back into preferences right away you'll see it's set back to
<b>
in version 3.4.1 btw
You're right.
I'll correct that.
But the option is correctly save so it should work, as long as you do not go back to the Preferences window
