Vista 64bits?
accidburn
Vista 64bits?
Post by accidburn »
Hello all!
I would like to know if the last version is compatible with Vista 64bits?
Thank you very much
It should work on the 64bits like on Vista 32bits I guess, as there is some backward compatibility for 32bits apps.
