IMDB script doesn't work
kalimagdora
Post by kalimagdora »
Does it just not work for me IMDB?
Error code
HTPP/1.1404
thx
Garfield
Re: IMDB script
Post by Garfield »
I have the same problem
phil5660
Re: IMDB script
Post by phil5660 »
Same for me. Same error...
Thank you in advance !
u28151
Re: IMDB script
Post by u28151 »
I have the same problem. Grateful for some assistance!
brgds / U
HaraldBluetooth
Re: IMDB script doesn't work
Post by HaraldBluetooth »
I have the same problem, hope it can be fixed :)
Hi, indeed, a fix is needed.
In the meantime it works if you provide the link to the IMDb page of the movie when it asks for the title. The problem is just with the search when selecting an entry.
It should be easy to fix, I'll try to do that in the next days.
Fixed as version 4.029 to get via "Update scripts" or https://update.antp.be/amc/scripts/
HaraldBluetooth
Thanks a lot, it works now :)
kalimagdora
Thank you very much. It works perfectly :clapping:
phil5660
Post by phil5660 »
Many thanks, it works for me too.
Garfield
Post by Garfield »
Wow. Thank you very much. It works perfectly :)
severus
Post by severus »
antp wrote: 2024-09-07 09:24:22 Fixed as version 4.029 to get via "Update scripts" or https://update.antp.be/amc/scripts/
Merci pour la Mise à jour :clapping:
Il y a il une possibilité de réparer l'import des trivia qui n'est plus fonctionnel depuis déjà quelque temps.
Merci pour le travail effectué.
En effet corriger les trivia c'est sur ma to-do list, mais je n'ai pas vraiment le temps de m'en occuper (tellement d'autres choses à faire) donc peu de chances que ça arrive à moins que quelqu'un d'autre ne le fasse :/
saraddasi
Post by saraddasi »
Hello, I run the IMdb script (version 4.030) on latest AMC (4.2.3) but just can't import anything with no error message. Need help. Thank you.
It seems to work for me.
Maybe it is related to one of the options.
What happens exactly? Does the title search work? If so, it just returns an empty results page at the end?
saraddasi
Post by saraddasi »
Hi. Yes, it just returns an empty results page at the end.
Sorry, I don't check the forum very often, it has already been a week :/
Does the problem occur with all movies?
If so, can you make a screen captures of the options you have set? (the panels on the right of the scripts window)
You can post the image on a public image hosting site, or use http://ksle1.antp.be/upload.php to send it to me directly.
Dorohedoro
Post by Dorohedoro »
The empty page issue is happening to me too, and it's random with the code "system error Code: 1447"
Maybe it has to do with the new imdb layout format in the web?
Lemaireus
Post by Lemaireus »
antp wrote: 2025-06-09 18:30:06 Sorry, I don't check the forum very often, it has already been a week :/
Antoine, I have posted screenshots and quoted the errors that many of us are getting here:
viewtopic.php?p=92096#p92096
These are by no means the only errors. Basically, the IMDB script has been rendered dysfunctional; in fact, one can't even delete these dead, dysfunctional entries.
IMDb is doing some changes indeed, and it seems to work quite randomly currently.
I hope that it will stabilize soon. I'll try to take a look at it next week.
