Integration with carousels?
DerekLee1
Post by DerekLee1 »
Does Ant link with or can it be integrated with any of the carousel storage systems like Disc Stakka, Centurion, or ZioTek Media Carousel? If not, it would be fantastic to use Ant to catalog and browse movies, then have it spit the disc out of one of those systems. thanks!
Nothing as been done for that as far as I know.
I guess it must be rather easy, if the storage device can be accessed through some DLL (as I guess it would be the case), but it would be easier to have that done by someone who has both Delphi knowledge and such device to test it.
