Exporting with command line
z3us
Post by z3us »
Is it possible to use the command line when exporting the catalog to another format?
No, it is planned to add such feature in "some future version", but it is not possibe in current version.
But if you wish to run export in one shortcut, you may achieve using AutoIt for example
z3us
Post by z3us »
Is there any tool that allow to convert from xml to sql (same way AMC do) using command line?
Not as far as I know
