image location
biker72
image location
Post by biker72 »
Hi Antoine,
I know it's possible to change the location of the pics by editing the xml file. But it would be nice if there was a setting which states the directory where the images are stored (ie. relative to the program directory).
With this option there's greater freedom where to put your images.
It would also be a first solution to make it possible to switch between thumbs and normal sized pics. At this moment I have two directories where thumbs and normal sized covers are stored. Normally i use the covers for presentation, but for the smaller html lists I would like the thumbs to be shown. With such a setting switching would be easy whenever I print such a list.
Another advantage would be that the catalog and possible html-templates are seperated from the long list of pics which is easier in terms of maintainance.
I couldn't find it, but is there a list of future changes which are on your to-do list? I would make it easier to browse so we all can see what's coming our way?
Thanks and keep up the great work :)
Indeed I should add an option for a "default picture folder", it would be easier as you said.
There is no public to-do list. Making a public list is also on my to-do list :D
(current list has both French & English mixed, but mostly French)
