How can I get contents from a local File?
I have a local file "c:\commenti.txt" and I would like to extract lines containing certain words:
now
I like
this
program.
This
is the reason
why
I want to extract
this
How can I open the file and filter it?
Thank you! ;)
Re: How can I get contents from a local File?
The TStringList class has LoadFromFile and SaveToFile functions that you can use for that:
function GetLocalFile(Path: string): string;
  File: TStringList;
  FileName: string;
  File:= TStringList.Create;
  FileName := Path;
  Input('', 'File to read:', FileName);
  File.LoadFromFile(FileName);
  Result := File.Text;
  File.Free;
This is a demo function. If you want to process it line per line, you can of course directly use the TStringList object (named "File" here)
:grinking: i'll try!
