Hello y'all. I've got a REALLY GREAT IDEA for an additional option to add to Ant Movie Catalogue----a "UPC CODE" input option meaning that if you input the UPC Code from the DVD case (the same UPC Code that the store uses at the check out) it automatically searches the Internet for the movie info and then downloads it. WOO HOO WAY COOL OPTION eh
Currently this works with the AmazonWSPro script if not used in batch mode. Take care to switch script option "AmazonVersion" to correct country setting, else you might not get any results.
