Title Formatting
stdo909
Title Formatting
Post by stdo909 »
If the "Translated title (Original title)" setting is selected for "Title to display", this results in a Formatted title that depends on which title fields contain text. For example, if both the Original title and the Translated title are specified, the Original title appears in brackets after the Translated title. If, on the other hand, no Translated title is specified, only the Original title is displayed, without the brackets.
Is it possible to achieve a behavior like that for the "Custom title" setting? (display e.g. brackets or a separator depending on whether a certain field is empty or not)
Many thanks in advance!
Re: Title Formatting
Sorry, no: that formatting is very basic, so it simply interprets the field names between brackets but does not do any additional test on the values
