scripts & HTML templates
these 2 hot things in the program are demanding a new section here on the site for ppl to share their scripts or templates with others
here is a nice HTML template to export your list
<html><head>
<style TYPE="text/css">
  text,body,p,div,span,th,td,ul,li { FONT-SIZE: 10pt; FONT-FAMILY: Trebuchet MS, Verdana, Arial, Helvetica, sans-serif; color: black; background: white; }
  HR { color: black; }
  A:link { COLOR: #003399; background: white; }
  A:visited { COLOR: #003399; background: white; }
  A:hover { COLOR: #CC0000; background: white; }
  A:active { COLOR: #CC0000; background: white; }
  td.blk { color: white; background: black; border: solid; border-color: black; }
  table.blk { color: white; background: black; border: solid; border-color: black; border-width: thin; }
  table.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
  td.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
  p.title { font-size: 18pt; font-weight: bold; }
</style></head><body>
<p>Catalog created on $$DATE with <a href="http://www.buypin.com/moviecatalog.php" target="_blank">Ant Movie Catalog</a>.</p>
<table class="blk" border="1" cellspacing="0" cellpadding="5"><tr>
<td class="blk" nowrap>Number</td>
<td class="blk" nowrap>Original Title</td>
<td class="blk" nowrap>Translated Title</td>
<td class="blk" nowrap>Group Release</td>
<td class="blk" nowrap>CDs</td>
<td class="blk" nowrap>Format</td>
</tr>$$ITEM_BEGIN<tr>
<td rowspan="2" class="lgt"><strong>$$ITEM_NUMBER $$ITEM_APPRECIATION<br><a href= $$ITEM_URL target="_blank"><img src="$$ITEM_PICTUREFILENAME" width="120" height="166"> </a></strong></td>
<td class="lgt"><strong><a href= $$ITEM_URL target="_blank">$$ITEM_ORIGINALTITLE </a></strong></td>
<td class="lgt"><strong><a href= $$ITEM_URL target="_blank">$$ITEM_TRANSLATEDTITLE </a></td>
<td class="lgt">$$ITEM_PRODUCER </td>
<td class="lgt">$$ITEM_DISKS </td>
<td class="lgt">$$ITEM_TYPE </td>
</tr><tr><td colspan="6" class="lgt">$$ITEM_DESCRIPTION </td></tr><tr><td colspan="7" class="blk"></td>
</tr>$$ITEM_END</table><p><strong>Total: $$TOTALMOVIES movies</strong></p></body></html>
everyone are welcome to put their scripts or templates here :)
especialy the dude with the export to ORIGONS script :p
I will add a section for contributions (templates, scripts, translations).
What does this template have different from the original one ?
automatic IMDB + small pic script
its not perfect but it works if you have the link to the movie on imdb already or only the imdb id only ...only in URL field
1)bring the pic. first
2)takes the first plot summary there is and puts it in the description field
3)puts the plot outline or tagline in the comments field.
if you have another link in the URL that is different than the imdb it will skip the movie and move on to the next one.
// GETINFO SCRIPTING
// IMDB (US) ** Automatic ** import with small picture
(* things to work on description import:
   1) Plot summary import some summary contain
      links in the summary , need to check <> tags
      in the summary itself and delete them
   2) if there is no plot outline & no tagline to import a
      user comment if available ( 10 lines top !! usaily those users write nevels there :) ).
 *      IMDB (US), http://us.imdb.com              *
 *  (c) 2002 Antoine Potten    antoine@buypin.com  *
 *  Improvements made by Danny Falkov              *
 *  For use with Ant Movie Catalog 3.3.0           *
program AutoIMDb;
  MovieName,id,IMDBid: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
//  Page.Text := Page2;
  if pos('<TITLE>IMDb', Page.Text) = 0 then
    AnalyzeMoviePage(Page)
    LineNr := 0;
    LineNr := FindLine('<H2><A NAME="top">Most popular searches</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Most popular searches', '');
    LineNr := FindLine('<H2><A NAME="mov">Movies</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Movies', '');
    LineNr := FindLine('<H2><A NAME="tvm">TV-Movies</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('TV-Movies', '');
    LineNr := FindLine('<H2><A NAME="vid">Made for video</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Made for video', '');
      AnalyzePage(Address);
  Line, Value, FullValue: string;
  BeginPos, EndPos: Integer;
  // Original Title & Year
  LineNr := FindLine('<TITLE>', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<TITLE>', Line);
    if BeginPos > 0 then
      BeginPos := BeginPos + 7;
    EndPos := pos('(', Line);
    if EndPos = 0 then
      EndPos := Length(Line);
    HTMLDecode(Value);
      EndPos := pos(')', Line);
      SetField(fieldYear, Value);
  //URL
  LineNr := FindLine('<BASE HREF="', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<BASE HREF="', Line) + 12;
    EndPos := pos('">', Line);
    SetField(fieldURL, Value);
  // Picture
  LineNr := FindLine('<IMG SRC="http://posters.imdb.com/', Page, 0);
  if LineNr < 0 then
    LineNr := FindLine('<A HREF="/ImageView?', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<IMG SRC="', Line) + 10;
    EndPos := pos('ALT="cover" ', Line);
    if (BeginPos > 10) and (EndPos > 0) then
      Value := copy(Line, BeginPos, EndPos - BeginPos - 2);
      GetPicture(Value, False); // False = do not store picture externally ; store it in the catalog file
  // Rating
  if LineNr > -1 then
    BeginPos := pos('<B>', Line) + 3;
    SetField(fieldRating, Value);
  // Director
  if LineNr > -1 then
    FullValue := '';
      LineNr := LineNr + 1;
      EndPos := pos('</A>', Line);
        if FullValue <> '' then
    until (pos('<BR><BR>', Line) > 0) or (LineNr >= Page.Count-1) or (Line = '<BR>');
    HTMLDecode(FullValue);
  // Actors
  LineNr := FindLine('Cast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('cast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('Complete credited cast', Page, 0);
  if LineNr > -1 then
    FullValue := '';
      if pos('<TD VALIGN="TOP">', Line) > 0 then
        Line := '';
    until Line = '';
  //Country
  LineNr := FindLine('Country</B>', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Category
  LineNr := FindLine('Genre</B>', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Description
  LineNr := FindLine('Plot Summary:', Page, 0);
  if LineNr < 1 then
    LineNr := FindLine('Plot Outline:', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('</B>', Line) + 4;
    EndPos := pos('<A HREF', Line);
    if EndPos < 1 then
    PickListClear;
    HTMLDecode(Value);
      // put the plot outline in the comments field , to disable it delete the line below
    BeginPos := pos('/Plot?', Line);
    EndPos := pos('"> (more)', Line);
    GetDescriptions(Value);
    //Value := '';
    //if PickListExec('Select a description for "' + MovieName + '"', Value) then
  //Length
  LineNr :=FindLine('Runtime</B>:', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('</B>', Line) + 7;
    EndPos := pos(' /', Line);
    if EndPos = 0 then
      EndPos := pos('</TD>', Line);
    SetField(fieldLength, Value);
  // Language
  LineNr := FindLine('Language</B>:', Page, 0);
  if LineNr > -1 then
    if EndPos = 0 then
  DisplayResults;
procedure GetDescriptions(Address: string);
  Line, Value: string;
  Page.Text := GetPage('http://us.imdb.com' + Address);
  LineNr := FindLine('<P CLASS="plotpar">', Page, 0);
  if LineNr > -1 then
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</P>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</P>', Line) > 0);
    LineNr := FindLine('<P CLASS="plotpar">', Page, LineNr);
  StartPos: Integer;
    StartPos := pos('="', Line);
    if StartPos > 0 then
      Startpos := Startpos + 2;
      MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
      MovieTitle := copy(Line, StartPos, pos('</A>', Line) - StartPos);
      HTMLDecode(Movietitle);
      PickTreeAdd(MovieTitle, 'http://us.imdb.com' + MovieAddress);
  until pos('</OL>', Line) > 0;
  // add zeros to imdb id to be a 7 chars id
procedure GetIMDBid ();
  URLfield : string;
  URLfield := '' ;
    // if the imdb id is in another field then add\change this field here
  URLfield:=GetField(fieldURL);
  if  (length(URLfield) =  7)  then IMDBid := URLfield
    else if (length(URLfield) <  7) then
        i := Length(URLfield);
        for i := 1 to 7 - Length(URLfield) do
          IMDBid := IMDBid + '0';
        IMDBid := IMDBid + URLfield;
          // if the URL has already a link to IMDB then get the id
       //else if ( (length(URLfield) - pos('?' , URLfield)) > 7 ) then
        IMDBid := copy(URLfield , pos('?' , URLfield)+1 , Length(URLfield)+1);
  //  main script
 IMDBid := '';
 GetIMDBid();
 if (length(IMDBid) > 2) then
 AnalyzePage('http://us.imdb.com/Title?' + IMDBid );
enjoy...now this program defenetly rules
took 1 hour to import all my 500 movies :hihi:
Ok thanks I will probably include it next time I update the installation package.
small change ...
change this line
to this
if ( (length(URLfield) - pos('?' , URLfield)) = 7 ) then
now it will skip movies with different URL than us.imdb...
:grinking:
still waiting for that section u promissed .... ...all we want is to share the files here
As I said on the other topic, I'll do that now ;)
