AMC Catalog
Purcy63
AMC Catalog
Post by Purcy63 »
Hi, due to a recent change of computers, I have two movie catalogs. Question I have, is it possible to compare and combine them?
Regards
Re: AMC Catalog
You can:
1) put differents words in a free field so you can distinguish the first catalog from the second
2) take the first catalog and import movied from the second
3) renumber the catalog in order by original title (or translated title) and the field at point 1
4) "save as"the resulting catalog with a n ew name
5) execute a script so to individuate "double" movies and list the in a .csv file
If you think to be able to execute first 4 steps and you say to me which field you choosed to distinguish catalogs, I'll give you the script I said at 5),
:innocent: :innocent:
