Auto Execution
Purcy63
Auto Execution
Post by Purcy63 »
I have recently changed computers and reloaded Ant Movie Catalogue. Previously when running scripts for multiple movie it would automatically move to the next title. When running them now, a window presents itself with the title name, I then need to hit ok, a script runs and another window presents itself, showing a number of different movie titles I need to choose. I need to pick which movie, hit ok, and then the remainder of the script runs, and then repeat for the next movie. Is there a check button I need to engage to have these scripts run automatically?
Re: Auto Execution
what script are you talking about? :??:
Purcy63
Re: Auto Execution
Post by Purcy63 »
IMDB
Re: Auto Execution
I hope your script IMDB is version 4.024 and verify these options using it:
:innocent:
Purcy63
Re: Auto Execution
Post by Purcy63 »
Thank you fulvio53s03, will give it a go. Cheers
Re: Auto Execution
For IMDb, there is the "batch mode" option
