Scrip to print title
Edu
Post by Edu »
I'm looking for a Scrip that allows me to justify printing the title of a movie
For example:
La Momia: La Tumba del Emperador Dragón
and it imprimera like this:
La Momia
Thank you
Scrip para imprimir titulo
Estoy buscando un scrip que me permita justificar al imprimir el titulo de una pelicula
Por ejemplo:
y que lo imprimera asi:
La Momia
Gracias
You mean in a template? to use in the report designer?
Edu
Post by Edu »
Although poorly explained by my hand, it seems to me, you read the thought.
is for use in Report Designer
Aunque mal explicado por mi parte, parece que me has leido el pensamiento.
Es para utilizar en Report Designer
So you want to put on 2 lines the title that contain a ":" ?
It is probably possible, though that I am not really sure on how to do it easily...
Maybe a little script that splits the title to two unused fields, then use these for printing. Not a nice solution, but an easy one ;)
Yes, though that it is possible to use some script commands in the report designer...
Huh.. is it ? I thought about doing that before using the report designer (just in case that was misunderstandable)
Yes, for text blocs you have a "script" checkbox
If you check the help file I think I included some basic info about that, but it does not always work and it acts a little weird sometimes...
Just didn't know about that. I should have a closer look on report designer some day, as I would like to have a template for printing on DVDs.
AoF-Neptune
Post by AoF-Neptune »
Another way is to simply replace ":" with "<br>" if for creating html page.
Not very nice but efficient.
