[FR] script pour Import DVD X (films de charme)
Rincevent
Post by Rincevent »
Voici un petit script pour les amateurs de films X :hihi: .
This is a script for XXX movies.
Fields are fill with french information (french site).
:cool:
Import DVD X.ifs
// GETINFO SCRIPTING
// Import DVD X import with picture
 *      importdvdx.com, http://www.importdvdx.com  *
 *  (c) 2002 Rincevent                             *
program importdvdx;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
function DelFirstBlank(line: string): string;
  while (   (pos(' ', line) = 1)
         or (pos(#13, line) = 1)
         or (pos(#09, line) = 1)
         or (pos(#10, line) = 1) ) do
    Delete(line, 1, 1);
  result := line;
  MovieTitle,MovieAddress: string;
  BeginPos, EndPos: Integer;
  Line := GetPage(Address);
  if Pos('Best DVD X', Line) > 0 then
     BeginPos := pos('style="color:#FF0000">', Line);
     while (BeginPos > 0) do
         //titre := Page.GetString(LineNr);
         Delete(Line, 1, BeginPos + 20);
         MovieTitle := copy(Line, pos('>', Line) + 1, pos('</td>', Line) - 1);
         HTMLRemoveTags(MovieTitle);
         BeginPos := pos('rubriques/infos.php4?code=', Line);
         Delete(Line, 1, BeginPos -1);
         MovieAddress := copy(Line, 1, pos('&', Line) -1 );
         PickTreeAdd(MovieTitle, 'http://www.importdvdx.com/' + MovieAddress);
        AnalyzeMoviePage(Line);
procedure AnalyzeMoviePage(PageContents: string);
  Line, Value: string;
  LineNr, BeginPos, EndPos: Integer;
  //Titre
  BeginPos := Pos('id="gd">', PageContents);
  delete(PageContents,1,BeginPos+7);
  //SetField(fieldComments,PageContents );
  // Titles traduit
  EndPos := Pos('</font>', PageContents);
  Value := copy(PageContents, 0, EndPos);
  Value :=StringReplace(Value, '<center>', ' ');
  HTMLRemoveTags(Value);
  //Value :=StringReplace(Value, #09, '');
  //Value :=StringReplace(Value, #13#10 , '');
   // Year
  BeginPos := Pos('id="sl">', PageContents);
  delete(PageContents,1,BeginPos+4);
  EndPos := Pos(')', PageContents);
  Value := copy(PageContents, Pos('(', PageContents), EndPos -1);
  //Value :=StringReplace(Value, ' ' , '');
  Value :=StringReplace(Value, '(' , '');
  Value :=StringReplace(Value, ')' , '');
  SetField(fieldYear, Value);
  // Producer
  BeginPos := Pos('Studio :', PageContents);
  EndPos := Pos('</a>', PageContents);
  Value := DelFirstBlank(Value);
  // Category
  BeginPos := Pos('Genre :', PageContents);
  delete(PageContents,1,BeginPos+6);
  if (Pos(Value,'GENERAL') >0) then
        Value := 'Film X'
        Value := 'Film X - ' + Value;
  SetField(fieldCategory,  Value);
  // Picture
  BeginPos := Pos('src="/fiches_produits/images_site/images_fiches2/', PageContents);
  delete(PageContents,1,BeginPos - 1);
  delete(PageContents,1,  Pos('2/', PageContents) +1);
  EndPos := Pos('.jpg', PageContents);
  Value := Copy(PageContents, 1, EndPos + 3);
  GetPicture('http://www.importdvdx.com/fiches_produits/images_site/images_fiches/' + Value, False);
  //SetField(fieldComments, 'http://www.importdvdx.com/fiches_produits/images_site/images_fiches/' + Value);
  //NAME=scenario
  BeginPos := Pos('id="sp">', PageContents);
  delete(PageContents,1,BeginPos + 7);
  EndPos := Pos('<font', PageContents);
  Value := copy(PageContents, 0, EndPos-1);
  HTMLDecode(Value);
  //Realisateur
  BeginPos := Pos('Réalisé par :', PageContents);
  delete(PageContents,1,BeginPos + 26);
  // Acteurs
  BeginPos := Pos('id="sp">Avec :', PageContents);
  delete(PageContents,Pos(':', PageContents),BeginPos + 13);
  Value := copy(PageContents, 0, EndPos -1);
  Value :=StringReplace(Value, ', ' , ',');
  Value :=StringReplace(Value, ',' , #13#10);
  SetField(fieldActors, Value);
   // Length
  BeginPos := Pos('id="spl">Durée :', PageContents);
  delete(PageContents,1,BeginPos+19);
  delete(PageContents,1,Pos(':', PageContents)+1);
  EndPos := Pos('mn', PageContents);
  Value := copy(PageContents, 1, EndPos -1);
  SetField(fieldLength, Value);
  DisplayResults;
  if CheckVersion(3,4,1) then
    if Input('importdvdx.com Import', 'Entrez le titre du film :', MovieName) then
    AnalyzePage('http://www.importdvdx.com/indexSite.fan?rub=DVD&pro=1&News=2&Precos=1&ban=2&Power=rubrique&categ=1&rubrik=1&motscles='+UrlEncode(MovieName)+'&zero=1&triMC=1');
    //MovieName := 'http://www.importdvdx.com/rubriques/infos.php4?code=2202';
    //AnalyzeMoviePage(MovieName);
   // ShowMessage('Ce script requiert la version 3.4.1 ou supérieure de Ant Movie Catalog.');
Thanks ;)
kubilai
Post by kubilai »
merci bcp !
@pitbull
Post by @pitbull »
yes merci beaucoup+++++++++++
ne marche plus j'ai une error 87 de socket
gest
Post by gest »
Doesn't work :
Socket error #11001
Host not Fond
:cry:
lecrick
Post by lecrick »
Si éventuellement qqun a du neuf sur cet erreur de socket?
katchimbo
même erreur de socket...
Post by katchimbo »
Que dois je faire pour supprimer cette erreur de socket?
Le script bloque certains clients (programmes)
Je suppose qu'ils ne veulent pas que l'on télécharge leurs infos.
Et de toute façon même quand on contourne ce problème-là, il y a d'autres erreurs dues au fait que le site a changé et que le script ne correspond plus :/
bobo
Post by bobo »
c con :(
qqun conné un scipt qui marche (même sur un autre site, le principal étant que ce soit du Q :hihi:
