[UA] share.net.ua
yasia22
[UA] share.net.ua
Post by yasia22 »
Script for the site http://www.share.net.ua/forum/.
Ukrainian movies, documentary, subtitles.
Скрипт для сайту http://www.share.net.ua/forum/.
Українські фільми, закордонні фільми з українським дубляжем та/або субтитрами, документальне відео.
Попередження: оформлення фільмів на форумі не уніфіковане, тому скрипт не завжди працює коректно. Але працює ;)
Authors=yasia22
Title=ShareNetUA
Description=Movie importation script for Share.Net.UA forum
Site=www.share.net.ua
Language=UA
Version=0.2 (2008-10-28)
Requires=3.5.1
Comments=This script is not 100% accurate, as forum users describe movies in many different ways.
License=This program is free software; you can redistribute it and/or modify it under the  terms of the GNU General Public License as published by the Free Software Foundation;  either version 2 of the License, or (at your option) any later version.
ActorsLayout=0|0|0=Actors separated by commas|1=Actors separated by linebreaks
Awards=1|1|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not ask for movie title, but halts if no movie found
CrewMembers=1|1|0=Don't get any of the crew|1=Get the writer only|2=Get all available
VideoType=0|0|0=Ukrainian|1=Subtitled|2=Documentary|3=Without translation
program ShareNetUa;
uses StringUtils1;
    MovieName: String;
    MovieURL: String;
    MovieNumber: String;
    isFound: Boolean;
    FoundAddr: String;
// *** Analyze search results page *** //
// *** @input: link to the forum thread of movies/video *** //
// *** @ouput: list of movies *** //
// *** Calls AnalyzeMoviePage() if exact movie found *** //
procedure AnalyzePage(Address: String);
    PageStr, MovieAddr, MovieTitle, MovieYear, MovieID: String;
    BeginPos, EndPos: Integer;
    LastPage: Boolean;
    Pages: Integer;
    MovieCount: Integer;
    LastPage := False;
    PageStr := GetPage(Address);
    Pages := StrToInt(Copy(TextBetween(PageStr, 'ipbpagespan', '</div>'), LastPos('</a>', TextBetween(PageStr, 'ipbpagespan', '</div>')) - 1, 1), 1);
    if ((0 = Pos('-', Address)) and (0 < Pages)) then
        for MovieCount := 0 to Pages - 1 do
            AnalyzePage(Address + '-' + IntToStr(MovieCount * 150));
    if (0 < Pos('-0', Address)) then
    if (0 < Pos('-' + IntToStr(150 * (Pages - 1)), Address)) then
        LastPage := True;
    BeginPos := Pos('<ol>', PageStr);
    if (BeginPos > 0) then
        Delete(PageStr, 1, BeginPos);
        BeginPos := Pos('<li>', PageStr);
        EndPos := 1;
        while ((BeginPos > 0) and (EndPos > 0) and not (isFound)) do
            EndPos := Pos('</li>', PageStr);
            MovieID := TextBetween(PageStr, '?t', '.html');
            MovieAddr := 'http://www.share.net.ua/forum/index.php?showtopic=' + MovieID ;
            MovieTitle := TextBetween(PageStr, '>', '</a>');
            HTMLRemoveTags(MovieTitle);
            HTMLDecode(MovieTitle);
            MovieYear := TextBetween(MovieTitle, ' (', ')');
            if 0 < Length(MovieYear) then
                MovieTitle := TextBefore(MovieTitle, ' (', '');
            if (EqualIgnoreCase(MovieName, MovieTitle)) then
                isFound := True;
                FoundAddr := MovieAddr;
            end; // names are equal
            PickTreeAdd(MovieTitle + ' (' + MovieYear + ')', MovieAddr);
            if (Pos('</ol>', PageStr) < BeginPos) then
                BeginPos := -1;
        end; // while there are more movies to add
    end; // if there are any search results
    if (LastPage) then
        if (isFound) then
            AnalyzeMoviePage(FoundAddr)
            PickTreeSort;
                AnalyzeMoviePage(Address);
        end; // exact movie title was not found
    end; // last page
// *** End of AnalyzePage() *** //
// *** Analyze particular movie page *** //
// *** @input: link to the movie page*** //
// *** @output: parsed values *** //
procedure AnalyzeMoviePage(Address: String);
    PageStr: String;
    Item, Crew: String;
    DescStart: Integer;
    // *  Original title and year* //
    if (CanSetField(fieldOriginalTitle)) then
        Item := GetProperty(PageStr, 'font-size:14pt;', '</span>', '<b>', '</b>');
        if (0 < Length(TextBetween(Item, ' (', ')'))) then
            SetField(fieldYear, TextBetween(Item, ' (', ')'));
            SetField(fieldOriginalTitle, TextBefore(Item, ' (', ''));
    end; // Original title
    // * Director(s) * //
    if (CanSetField(fieldDirector)) then
        SetField(fieldDirector, GetProperty(PageStr, 'Режисер', '/>', ' ', '<br'));
    // *  Studio * //
    if (CanSetField(fieldCountry)) then
        Item := GetProperty(PageStr, 'Кіностудія', '/>', ' ', '<br');
        if (0 = Length(Item)) then
            Item := GetProperty(PageStr, 'Країна', '/>', ' ', '<br');
            Item := GetProperty(PageStr, '<span style=''color:gray''', 'br />', '>', '<');
            Item := TextBefore(Item, ',', '');
        if Pos('Довженка', Item) > 0 then
            Item := 'Довженка';
        SetField(fieldCountry, Item);
    end; // Studio/country added
    // *  Category * //
    if (CanSetField(fieldCategory)) then
        SetField(fieldCategory, GetProperty(PageStr, 'Жанр', '/>', ' ', '<br'));
    // *  Length * //
    if (CanSetField(fieldLength)) then
        Item := GetProperty(PageStr, 'Тривалість', '/>', ' ', ' хв');
            Item := GetProperty(PageStr, 'Тривалість', '/>', ' ', '<br');
            Item := IntToStr(StrToInt(TextBefore(Item, ':', ''), 0) * 60 + StrToInt(TextBetween(Item, ':', ':'), 0));
        SetField(fieldLength, Item);
    // * URL * //
    if (CanSetField(fieldURL)) then
    // *  Description * //
    if (CanSetField(fieldDescription)) then
        Item := PageStr;
        DescStart := Pos('</span><br /><br />', Item);
        while (DescStart = Pos('</span><br /><br /><', PageStr)) do
            Delete(Item, 1, DescStart);
        Item := GetProperty(Item, '</span><br /><br /', 'br /><br /><', '>', '<');
    end; // Description
    // *  Picture * //
    if (CanSetPicture) then
        ImportPicture(PageStr, '', '<div class="postcolor">', '</div>');
    // * Actor(s) * //
    if (CanSetField(fieldActors)) then
        Item := GetProperty(PageStr, 'ролях', '/>', ' ', '<br');
            Item := GetProperty(PageStr, 'Актор', '/>', ' ', '<br');
        if (1 = GetOption('ActorsLayout')) then
        SetField(fieldActors, Item);
    end; // Actor(s) added
    // * Award(s) * //
    Item := GetProperty(PageStr, 'Нагород', '/>', ' ', '<br');
    Item := StringReplace(Item, '; ', #13#10);
    Item := StringReplace(Item, '. ', #13#10);
    case GetOption('Awards') of
        0:
            Item := '';
        1:
            if (Length(Item) > 0) then
                SetField(fieldDescription, GetField(fieldDescription) + #13#10#13#10 + Item);
        2:
                SetField(fieldComments, Item);
    end; // Case awards option
    // * Crew  members: writer(s), operator(s), composer(s), artist(s), sound editor(s) * //
    Crew := '';
    case GetOption('CrewMembers') of
        0: // No crew
            Crew := '';
        end; // case 0
        1: // Writer(s) only
            if (CanSetField(fieldProducer)) then
                Crew := GetProperty(PageStr, 'ценар', '/>', ' ', '<br');
                if (0 < Length(Crew)) then
                    Crew := StringReplace(Crew, ', ', ' (сценарист), ') + ' (сценарист)';
                SetField(fieldProducer, Crew);
            end; // Writer(s) found
        end; // case 1
        2: // Whole crew
            if (Pos('ценар', PageStr) > 0) then
                Item := GetProperty(PageStr, 'ценар', '/>', ' ', '<br');
                if (0 < Length(Item)) then
                    Item := StringReplace(Item, ', ', ' (сценарист), ') + ' (сценарист)';
                Crew := Item;
            end; // Writer(s)
            if (Pos('Композитор', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Композитор', '/>', ' ', '<br');
                Item := StringReplace(Item, ', ', ' (композитор), ') + ' (композитор)';
                if (Length(Crew) > 0) then
                    Crew := Crew + ', ';
                Crew := Crew + Item;
            end; // Composer(s)
            if (Pos('Оператор', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Оператор', '/>', ' ', '<br');
                Item := StringReplace(Item, ', ', ' (оператор), ') + ' (оператор)';
            end; // Operator(s)
            if (Pos('Художник', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Художник', '/>', ' ', '<br');
                Item := StringReplace(Item, ', ', ' (художник), ') + ' (художник)';
            end; // Artist(s)
            if (Pos('Звуко', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Звуко', '/>', ' ', '<br');
                Item := StringReplace(Item, ', ', ' (звукорежисер), ') + ' (звукорежисер)';
            end; // SoundEditor(s)
        end; //case 2
    end; // Case crew option
// *** End of AnalyzeMoviePage() *** //
// *** Compare two strings *** //
// *** @input: two strings *** //
// *** @output: boolean comparison result *** //
// *** Ignores case of input strings *** //
function EqualIgnoreCase(String1: string; String2: string): boolean;
    Result := True;
    if (Length(String1) = Length(String2)) then
        String1 := AnsiLowerCase(String1);
        String2 := AnsiLowerCase(String2);
        for i := 0 to Length(String1) do
            if (Copy(String1, i, 1) <> Copy(String2, i, 1)) then
                Result := False;
                Break
        Result := False;
// *** End of EqualIgnoreCase() *** //
// *** Get movie property *** //
// *** @input: string, and two pairs of boundaries*** //
// ***@output: parsed value, stripped of tags *** //
function GetProperty(PageStr: String; Start1: String; End1: String; Start2: String; End2: String): String;
    Item: String;
    Result := '';
    if (Pos(Start1, PageStr) > 0) then
        Item := TextBetween(PageStr, Start1, End1);
        Item := TextBetween(Item, Start2, End2);
        Item := StringReplace(Item, '<br>', #13#10);
        HTMLRemoveTags(Item);
        HTMLDecode(Item);
        Trim(Item);
        Result := Item;
// *** End of GetProperty() *** //
// *** Import a picture *** //
// *** @input: string, base url, and a pair of boundaries*** //
// ***@output: gets a picture *** //
procedure ImportPicture(PageStr: String; BaseURL: String; Start1: String; End1: String);
    Source: String;
    Source := TextBetween(PageStr, Start1, End1);
    if ('' <> Source) then
        if (0 < Pos('src=' + #39, Source)) then
            Source := TextBetween(Source, 'src=' + #39, #39)
        else if (0 < Pos('src="', Source)) then
            Source := BaseURL + TextBetween(Source, 'src="', '"');
        if (Source <> '') then
            GetPicture(Source);
        end; // picture exists
// *** End of ImportPicture() *** //
// *** Main function *** //
Begin
    if (CheckVersion(3,5,1)) then
        isFound := False;
        if (('' = MovieName) or (1 = GetOption('VideoType'))) then
        case GetOption('VideoType') of
            0: // Ukrainian
                if (1 = GetOption('BatchMode')) then
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f1')
                else if (Input('Імпорт з Share.Net.UA', 'Назва фільму:', MovieName)) then
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f1');
            end; // case 0
            1: // Subtitled
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f22')
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f22');
            end; // case 1
            2: // Documentary
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f13')
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f13');
            end; // case 2
            3: // Without translation
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f11')
                    AnalyzePage('http://www.share.net.ua/forum/lofiversion/index.php?f11');
            end; // case 3
        end; // video type switch
    end // version is fine
        ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.1.1)');
End.
Updated to version 0.2 on 2008-10-28.
Thanks, can you send it to me by e-mail like for the other one? (that I received, thanks, but I could not reply: your address seems to by blocked by my SMTP)
