Script for http://cinema.ptgate.pt
Yorgul
Post by Yorgul »
Here is a small adaptation for http://cinema.ptgate.pt.
It currently retrieves translated title, category and link to trailer (goes in comments)
Title, picture, director, actors, year and country are commented off.
// GETINFO SCRIPTING
// cinema.ptgate import with small picture
 *      http://cinema.ptgate.pt                    *
 *  (c) 2003 Yorgul                                *
program PTGATE;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  Line, MovieItem, MovieTitle, MovieAddress: string;
  TitlePos, BeginPos, EndPos, Found: Integer;
  List: TStringList;
  Line := GetPage(Address);
  if Pos('encontrou 0 resultados', Line) = 0 then
    PickTreeAdd('Search results for "'+MovieName+'"', '');
    BeginPos := Pos('pesquisa por título', Line);
    EndPos := Pos('Anterior', Line);
    Line := Copy(Line, BeginPos, EndPos - BeginPos);
    List := TStringList.Create;
      TitlePos := Pos('<a class=srch href=', Line);
      if TitlePos > 0 then
	Found := 1;
        Delete(Line, 1, TitlePos+19);
        MovieAddress := 'http://cinema.ptgate.pt/' + Copy(Line, 1, Pos('>', Line)-2);
        Delete(Line, 1, Pos('>', Line));
        EndPos := Pos('</a><br>', Line) - 1;
        MovieTitle := Copy(Line, 1, EndPos);
    until TitlePos = 0;
    if Found = 0 then
      PickTreeAdd('No results found.', 'http://cinema.ptgate.pt/arquivo.php?pesquisa='+UrlEncode(MovieName));
    List.Free;
    AnalyzeMoviePage(Address);
  Line, Value, FullValue, MovieAddress: string;
  BeginPos, EndPos: Integer;
  MovieAddress := Address;
  BeginPos := Pos('<!-- main -->', Line);
  EndPos := Pos('<!-- wall -->', Line);
  // picture
  // BeginPos := Pos('filmes/', Line);
  // if BeginPos > 0 then
  // begin
  //   Delete(Line, 1, BeginPos - 1);
  //   EndPos := Pos('.jpg', Line)+3;
  //   Value := 'http://cinema.ptgate.pt/' + (Copy(Line, 1, EndPos));
  //   GetPicture(Value, False);
  // end;
  // title
  BeginPos := Pos('<b class=ttl>', Line);
  Delete(Line, 1, BeginPos+17);
  EndPos := Pos('</', Line);
  Value := Copy(Line, 1, EndPos-1);
  HTMLDecode(Value);
  // translatedtitle (PT)
  BeginPos := Pos('<i class=subttl>', Line);
  Delete(Line, 1, BeginPos+15);
  EndPos := Pos('<', Line);
  HTMLDecode(Value);
  // Year
  // BeginPos := Pos('Ano:', Line);
  // Delete(Line, 1, BeginPos+41);
  // EndPos := Pos('</', Line);
  // Value := Copy(Line, 1, EndPos - 1);
  // HTMLDecode(Value);
  // SetField(fieldYear, Value);
  // Country
  // BeginPos := Pos('País:', Line);
  // Delete(Line, 1, BeginPos+42);
  // SetField(fieldCountry, Value);
  // Category
  BeginPos := Pos('Género:', Line);
  Delete(Line, 1, BeginPos+44);
  if Pos(' /', Line) = 0 then
    EndPos := Pos(' /', Line);
  HTMLDecode(Value);
  SetField(fieldCategory, trim(Value));
  // Director
  // BeginPos := Pos('Realizador:', Line);
  // Delete(Line, 1, BeginPos+53);
  // Value := Copy(Line, 1, EndPos - 4);
  // SetField(fieldDirector, Value);
  // Actors
  // BeginPos := Pos('Intérpretes:', Line);
  // Delete(Line, 1, BeginPos+54);
  // SetField(fieldActors, Value);
  // URL
  // BeginPos := Pos('Site oficial:', Line);
  // Delete(Line, 1, BeginPos+13);
  // BeginPos := Pos('size=2>', Line);
  // Delete(Line, 1, BeginPos+6);
  // if Value = 'Não disponível' then
  // else
  // begin
  //   MovieAddress := MovieAddress + ' ' + Value;
  // end;
  // SetField(fieldUrl, trim(MovieAddress));
  // Trailer
  BeginPos := Pos('Trailer:', Line);
  Delete(Line, 1, BeginPos+8);
  BeginPos := Pos('http://', Line);
  EndPos := Pos('>[', Line)-2;
  if pos('Não está disponível', Line) = 0 then
    HTMLDecode(Value);
    if pos('Trailer: ', getfield(fieldComments)) = 0 then
      SetField(fieldComments, 'Trailer: ' + Value + Chr(13) + Chr(10));
  DisplayResults;
  if CheckVersion(3,4,0) then
    if Input('Cinema.PTgate Import', 'Enter the title of the movie:', MovieName) then
      AnalyzePage('http://cinema.ptgate.pt/arquivo.php?pesquisa='+UrlEncode(MovieName));
Why disable title, actors, etc. ?
Yorgul
Post by Yorgul »
Well, this is mainly a "translation" script, and there are better places and scripts to get the other info. Too bad there is not a movie description, that's why I'm still hoping you can solve the problem with 7arte.net. ;)
Yorgul
Yorgul
Post by Yorgul »
Also, some directors and actors have links to other pages, and I'm still trying to get their names in both situations.
