I've been wondering if there's a way to import the number of votes and have it shown in the catalog in any way?
I'm using the IMDB script if it matters.
If it's impossible I'd really like such a feature to be added....
By the way...
I've been using AMC for about 4 years now, and absolutely loving it!
So a huge thanks flies out to the author
About the number of votes, I thought that it was already the case (or that there was an option for it) but I guess that I mixed it with another script in my mind then.
Technically it is possible and - I guess - not difficult. It just requires that someones adds it to the script to include it in comments for example...
// Votes Number
if CanSetField(fieldMediaType) then
Value := TextBetween(PageText, '<a href="ratings" class="tn15more">', '</a>');
As you can see it adds it to the MediaType field which I didn't use anyway, seems to work...
Hurray for me, my first script edit (if you can even call it that way), and I don't know shit about programming so I'm kinda excited
I added your code (with a new script option 'UserRatings' and some additional code) to IMDB script. User ratings with number of votes can be optionally imported to field Media Type or field comments. Thanks
I need another small assistance please.
I want to have a "Last Update" line in my template for each movie (this is because I'm going to go through each movie in my catalog to have the number of votes added).
For this I need the script to add the current system date and time to an empty field (e.g. subtitles), at the time of fetching info.
As you understand it's not like the "Date Added" feature.
Could anyone help me out and write a few lines that do this?
Or maybe even 3.5.1.2 (current dev version) but I think that I released one with these new functions as I remember that I had to re-upload few scripts to fix a problem: some scripts used a "date" variable which was now in conflict with the "date" function.
