[UA] kinokolo.ua
yasia22
[UA] kinokolo.ua
Post by yasia22 »
Script for the site http://www.kinokolo.ua/cyclopedia/.
Ukrainian movies (1927-2003), some pictures.
Скрипт для сайту http://www.kinokolo.ua/cyclopedia/.
Українські фільми (1927-2003), деякі зі скріншотами. На жаль, журнал вже не виходить, а сайт (Енциклопедія) не оновлюється. Якщо хтось знає схожу базу даних українських фільмів - дайте знати.
Authors=yasia22
Title=KinoKolo
Description=Movie importation script for Kino-Коло
Site=http://www.kinokolo.ua/
Language=UA
Version=0.2 (2008-10-28)
Requires=3.5.1
Comments=Unfortunately, the last issue of KINO-KOLO magazine was published in July '08 and the web site is not being updated anymore.
License=This program is free software; you can redistribute it and/or modify it under the  terms of the GNU General Public License as published by the Free Software Foundation;  either version 2 of the License, or (at your option) any later version.
ActorsLayout=0|0|0=Actors separated by commas|1=Actors separated by linebreaks
Awards=1|1|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not ask for movie title, but halts if no movie found
CrewMembers=1|1|0=Don't get any of the crew|1=Get the writer only|2=Get all available
program KinoKolo;
uses StringUtils1;
    MovieName: String;
    MovieURL: String;
    MovieNumber: String;
// *** Analyze search results page *** //
// *** @input: link to the list of movies that start with the first letter of the target movie *** //
// *** @ouput: list of movies *** //
// *** Calls AnalyzeMoviePage() if exact movie found *** //
procedure AnalyzePage(Address: String);
    PageStr, MovieAddr, MovieTitle, MovieYear, MovieID: String;
    BeginPos, EndPos: Integer;
    isFound: Boolean;
    isFound := False;
    PageStr := GetPage(Address);
    BeginPos := Pos('<hr noshade size="1"><br>', PageStr);
    if (BeginPos > 0) then
        Delete(PageStr, 1, BeginPos);
        BeginPos := Pos('<p>', PageStr);
        EndPos := 1;
        while ((BeginPos > 0) and (EndPos > 0) and not (isFound)) do
            EndPos := Pos('</p>', PageStr);
            MovieID := TextBetween(PageStr, '/cyclopedia/film.php/', '">');
            MovieAddr := 'http://www.kinokolo.ua/cyclopedia/film.php/' + MovieID;
            MovieTitle := TextBetween(PageStr, '">', '</a>');
            MovieYear := TextBetween(PageStr, '</a>, ', '  рік');
            if (EqualIgnoreCase(MovieName, MovieTitle)) then
                isFound := True;
            end; // names are equal
            PickTreeAdd(MovieTitle + ' (' + MovieYear + ')', MovieAddr);
            if(Pos('</div>', PageStr) < BeginPos) then
                BeginPos := -1;
        end; // while there are more movies to add
    end; // if there are any search results
    if (isFound) then
        AnalyzeMoviePage(MovieAddr)
            AnalyzeMoviePage(Address);
    end; // exact movie title was not found
// *** End of AnalyzePage() *** //
// *** Analyze particular movie page *** //
// *** @input: link to the movie page*** //
// *** @output: parsed values *** //
procedure AnalyzeMoviePage(Address: String);
    PageStr: String;
    Item, Crew, Awards: String;
    // *  Original title * //
    if (CanSetField(fieldOriginalTitle)) then
        SetField(fieldOriginalTitle, GetProperty(PageStr, '<h1', 'h1>', '>', '/'));
    // * Director(s) * //
    if (CanSetField(fieldDirector)) then
        SetField(fieldDirector, GetProperty(PageStr, '<b>Режисер', '<b>', '</b>', '<br>'));
    // *  Studio * //
    if (CanSetField(fieldCountry)) then
        Item := GetProperty(PageStr, '<b>Кіностудія', '<b>', '</b>', '<br>');
        if Pos('Довженка', Item) > 0 then
            Item := 'Довженка';
        SetField(fieldCountry, Item);
    end; // Studio added
    // *  Year * //
    if (CanSetField(fieldYear)) then
        SetField(fieldYear, GetProperty(PageStr, '<b>Рік', '<b>', '</b>', '<br>'));
    // *  Length * //
    if (CanSetField(fieldLength)) then
        SetField(fieldLength, GetProperty(PageStr, '<b>Час', '<b>', '</b>', ' хв'));
    // * URL * //
    if (CanSetField(fieldURL)) then
    // *  Description * //
    if (CanSetField(fieldDescription)) then
        SetField(fieldDescription, GetProperty(PageStr, '<br><p', '/div>', '>', '<'));
    // *  Picture * //
    if (CanSetPicture) then
        ImportPicture(PageStr, '', 'javascript: window.open', '</a>', 'src=' + #39, #39);
    // * Actor(s) * //
    if (CanSetField(fieldActors)) then
        Item := GetProperty(PageStr, '<b>Актор', '<b>', '</b>', '<br>');
        if (1 = GetOption('ActorsLayout')) then
        SetField(fieldActors, Item);
    end; // Actor(s) added
    // * Award(s) * //
    Item := GetProperty(PageStr, '<b>Нагороди', '<b>', '</b>', '<br>');
    Item := StringReplace(Item, '; ', #13#10);
    case GetOption('Awards') of
        0:
            Item := '';
        1:
            if (Length(Item) > 0) then
                SetField(fieldDescription, GetField(fieldDescription) + #13#10#13#10 + Item);
        2:
                SetField(fieldComments, Item);
    end; // Case awards option
    // * Crew  members: writer(s), operator(s), composer(s), artist(s), sound editor(s) * //
    Crew := '';
    case GetOption('CrewMembers') of
        0: // No crew
            Crew := '';
        end; // case 0
        1: // Writer(s) only
            if (CanSetField(fieldProducer)) then
                Crew := GetProperty(PageStr, '<b>Сценарист', '<b>', '</b>', '<br>');
                if (0 < Length(Crew)) then
                    Crew := StringReplace(Crew, ', ', ' (сценарист), ') + ' (сценарист)';
                SetField(fieldProducer, Crew);
            end; // Writer(s) found
        end; // case 1
        2: // Whole crew
            if (Pos('<b>Сценарист', PageStr) > 0) then
                Item := GetProperty(PageStr, '<b>Сценарист', '<b>', '</b>', '<br>');
                if (0 < Length(Item)) then
                    Item := StringReplace(Item, ', ', ' (сценарист), ') + ' (сценарист)';
                Crew := Item;
            end; // Writer(s)
            if (Pos('<b>Композитор', PageStr) > 0) then
                Item := GetProperty(PageStr, '<b>Композитор', '<b>', '</b>', '<br>');
                Item := StringReplace(Item, ', ', ' (композитор), ') + ' (композитор)';
                if (Length(Crew) > 0) then
                    Crew := Crew + ', ';
                Crew := Crew + Item;
            end; // Composer(s)
            if (Pos('<b>Оператор', PageStr) > 0) then
                Item := GetProperty(PageStr, '<b>Оператор', '<b>', '</b>', '<br>');
                Item := StringReplace(Item, ', ', ' (оператор), ') + ' (оператор)';
            end; // Operator(s)
            if (Pos('<b>Художник', PageStr) > 0) then
                Item := GetProperty(PageStr, '<b>Художник', '<b>', '</b>', '<br>');
                Item := StringReplace(Item, ', ', ' (художник), ') + ' (художник)';
            end; // Artist(s)
            if (Pos('<b>Звукорежисер', PageStr) > 0) then
                Item := GetProperty(PageStr, '<b>Звукорежисер', '<b>', '</b>', '<br>');
                Item := StringReplace(Item, ', ', ' (звукорежисер), ') + ' (звукорежисер)';
            end; // SoundEditor(s)
        end; //case 2
    end; // Case crew option
// *** End of AnalyzeMoviePage() *** //
// *** Returns the number of the first character as a string *** //
// *** @input: movie name *** //
// *** @output: movie's first letter position in the alphabet *** //
// *** First letter of a movie must be capital *** //
function FirstCharStr(MovieNameStr: String): String;
    Alphabet : String;
    FirstCharNum : Integer;
    Alphabet := 'АБВГҐДЕЄЖЗИІЇЙКЛМНОПРСТУФХЦЧШЩЮЯ';
    FirstCharNum := Pos(Copy(MovieNameStr, 1, 1), Alphabet) - 1;
    if ((FirstCharNum < 0) or (FirstCharNum > 31)) then
        FirstCharNum := 32;
    Result := IntToStr(FirstCharNum);
// *** End of FirstCharStr() *** //
// *** Compare two strings *** //
// *** @input: two strings *** //
// *** @output: boolean comparison result *** //
// *** Ignores case of input strings *** //
function EqualIgnoreCase(String1: string; String2: string): boolean;
    Result := True;
    if (Length(String1) = Length(String2)) then
        String1 := AnsiLowerCase(String1);
        String2 := AnsiLowerCase(String2);
        for i := 0 to Length(String1) do
            if (Copy(String1, i, 1) <> Copy(String2, i, 1)) then
                Result := False;
                Break
        Result := False;
// *** End of EqualIgnoreCase() *** //
// *** Get movie property *** //
// *** @input: string, and two pairs of boundaries*** //
// ***@output: parsed value, stripped of tags *** //
function GetProperty(PageStr: String; Start1: String; End1: String; Start2: String; End2: String): String;
    Item: String;
    Result := '';
    if (Pos(Start1, PageStr) > 0) then
        Item := TextBetween(PageStr, Start1, End1);
        Item := TextBetween(Item, Start2, End2);
        Item := StringReplace(Item, '<br>', #13#10);
        HTMLRemoveTags(Item);
        HTMLDecode(Item);
        Trim(Item);
        Result := Item;
// *** End of GetProperty() *** //
// *** Import a picture *** //
// *** @input: string, base url, and two pairs of boundaries*** //
// ***@output: gets a picture *** //
procedure ImportPicture(PageStr: String; BaseURL: String; Start1: String; End1: String; Start2: String; End2: String);
    Source: String;
    Source := TextBetween(PageStr, Start1, End1);
    if ('' <> Source) then
        Source := BaseURL + TextBetween(Source, Start2, End2);
            GetPicture(Source);
// *** End of ImportPicture() *** //
// *** Main function *** //
Begin
    if (CheckVersion(3,5,1)) then
        if ('' = MovieName) then
        if (1 = GetOption('BatchMode')) then
            AnalyzePage('http://www.kinokolo.ua/cyclopedia/index.php/ukr/0/' + FirstCharStr(MovieName))
        else if (Input('Імпорт з KINO-КОЛО', 'Назва фільму:', MovieName)) then
            AnalyzePage('http://www.kinokolo.ua/cyclopedia/index.php/ukr/0/' + FirstCharStr(MovieName));
    end // version is fine
        ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.1.1)');
End.
Updated to version 0.2 on 2008-10-28.
Can you send me the script by e-mail so I can include it with other scripts?
As I can't easily copy/paste cyrillic characters to plain text.
