I have done some bug fixing and released a new version 1.1.2.
Unfortunately a wrong html file was packaged earlier in version 1.1 causing problems in displaying the information.
Also as a courtesy to the help received from Bonzi, I have expanded the flags section with more East European flags.
The update can be downloaded here
BonieNL
Template for dynamic web page view version 1.1.2
bonienl
Nolle
Hoi,
I downloaded your template, it looks very good. But I hava a problem. I don't have the title bar: Rating, Title,... where you can click for the order. Is there some file to modify ?
Also the heater-functions doesn't work too... No action
Can you tell me what I did wrong ? I just want my list to be just the same as the demo-version
thanks,
EDIT: found how to reduce the size of the image
thanks,
bonienl
Nolle
bonienl
Version 1.1.3
For those who downloaded version 1.1.2 and have problems in displaying, try this updated version 1.1.3
BonieNL
BonieNL
bonienl
spiderman
bonienl
The easiest way to solve this is by introducing a non-digit character in the title (for example title becomes 300.) or fill in a sub-title (translated title).spiderman wrote:is it possible to work on an solution for titles with only digits?
Because the same routine is used for sorting numbers and alphabet it is not easy to change unless a new concept is put in place, for which I don't have the time to do it.
spiderman
load image regioncode
some movies are playable in more than 1 regioncode. for instance region 2 and 4. for each region i want to load it's own image. an image for r2 and another image for r4. I can't get it right. (the same possiblities as the languages/country flags options)
thanks in advanced
thanks in advanced
