Extracting informations from Bonelli Editore Italian Comics
Dear Friends,
I'm trying to write a script to extract informations from a comics site: http://www.sergiobonellieditore.it
The site has no page of search but all pages have a very easy address (such: 'http://www.sergiobonellieditore.it/auto ... 1&subnum=0') where all characters but '501' are fixed and '501' is the number of collection of the comic.
It looks like easy to extract every information with a script using as original title the number of collection but.... i don't succeed in inserting the char '&' in the url of the page I'm trying to construct in my script to extract informations from the site.
Is there any problem using special characters as '&' ?
Could you help me?
:ha:
I'm sorry for my 'maccheronico' english, of course.
Re: Extracting informations from Bonelli Editore Italian Com
itemURL := 'http://www.sergiobonellieditore.it/auto/alborist?collana=' + value1 + '&numero=' + value2 + '&subnum=0';
It should be no problem to use a '&' this way. Value1 should be the comic series, value2 the comic number in this series. Of course all variables are defined as strings here.
Thank you!
It looks like just what I made... then the problem must be quite different.
This is my script:
Authors=Fulvio53s03
Title=Estrai Tex
Description=Estrae dati dei fumetti di Tex
Site=
Language=IT
Version=1 del 9/09/2008
Requires=3.5
Comments=Lo script nécessita di ScorEpioNCommonScript.pas
License=
GetInfo=0
Aggiornamento=1|1|0=Oui|1=Non
Caso Scelto=3|3|0=Tutto minuscolo|1=Tout maiusculo|2=Prima lettera maiuscula|3=Prima lettera di ogni parola maiuscula
program NormalizzaCampi;
  ScorEpioNCommonScript, Pivlib; // Pivello's scripts common library
//  Pivlib; // Pivello's scripts common library
  VersionScript = '01 del 29/05/2008';
  NomScript = 'Normalizza Campi';
  UrlBase = 'http://www.sergiobonellieditore.it/auto/alborist?collana=1&numero=';
  // OriginalTitle
  UrlFine = '&subnum=0';
  QueryFilm = UrlBase + '/dizionario/recensione.asp?id=';
  ImagePath = UrlBase + '/filmclub/';
  InitTrama = '<div valign="TOP"><font size="2" face="Arial">';
  EndTrama = '</font></div>';
  Update, NewField, OldField, NewValue, Field, Abort, FirstExec, InitString, VideoFormat, EndString, MovieUrl, OriginalTitle : String;
  UrlRicerca, PageStr : String;
  BeginPos : Integer;
// inizio AnalyzeMoviePage
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
  cImage : string;
  // Get packed title main page
  PageStr := GetPageStr;
  // Translated Title field
  SetField(fieldTranslatedTitle, GetValue(PageStr, InitTrama, EndTrama, true,false));
  ShowMessage ('trama ' +   getfield(fieldTranslatedTitle))
/// fine AnalyzeMoviePage
// NORMALIZZA TITOLI, DESCRIZIONI, ATTORI
procedure ExtractInfo;
/// inizio Fulvio
// itemURL := 'http://www.sergiobonellieditore.it/auto/alborist?collana=' + value1 + '&numero=' + value2 + '&subnum=0';
// It should be no problem to use a '&' this way. Value1 should be the comic series,
// value2 the comic number in this series. Of course all variables are defined as strings here.
//    MovieUrl := 'http://www.sergiobonellieditore.it/auto/alborist?collana=' + getfield(fieldOriginalTitle) + UrlFine;
//    MovieUrl := UrlBase + getfield(fieldOriginalTitle) + UrlFine;
    MovieURL := 'http://www.sergiobonellieditore.it/auto/alborist?collana=' + '1' + '&numero=' + getfield(fieldOriginalTitle) + '&subnum=0';
    Showmessage ('***' + MovieUrl + '***')
    AnalyzeMoviePage;
// PROCEDURA PER ESEGUIRE LE NORMALIZZAZIONI
procedure executeTask();
     ExtractInfo;
// PROGRAMMA PRINCIPALE
  if CheckVersion(3,5,0) then
    if GetOption('Aggiornamento') = 0 then
       execMenuMAJ(VersionScript,NomScript);
    if (Abort <> 'O') then
         executeTask();
         FirstExec := 'N';
    ShowMessage('Ce script requiert une version plus récente de Ant Movie Catalog (au moins la version 3.5.0)');
where I want to extract only the collection 1 of the comics by Bonelli.
You can try it by only inputing the numbers 1 2 3 etc. in the Original Title Fields of an AMC catalog.
Please, where is the Error?
Thanks in advance!
Your URL seems ok, it's just the ShowMessage function that does not display the '&'.
I don't know anything about ScorEpioNCommonScript and Pivlib units, but your Extractinfo and AnalyzeMoviePage procedures seem quite incomplete, e.g. you do not handle variable MovieURL anymore or fetch the corresponding page using GetPage(MovieURL). Otherwise, if this should be done by one of the external units, you will have to call the proper procedure/function (not sure if such one exists!) and hand over the variable MovieURL to the external procedure.
Indeed most of the Windows component won't display the & since it is used to underline shortcut letters.
e.g. to get "File" you put "&File".
@fulvio53s03: I guess you are still new to scripting, so maybe you should start with a quite simplyfied, but better structured and commented script.. it might be easier to understand what exactly is going on. Sorry if I should be wrong with that ;)
Authors=
Title=sergiobonellieditore.it
Description=
Site=http://www.sergiobonellieditore.it/
Language=IT
Version=v.0.1.0
Requires=3.5.0
Comments=
License=
program sergiobonellieditore;
  StringUtils1;   // Script needs external unit StringUtils1.pas in scripts folder !
  ComicURL, ComicSeries, ComicNumber: string;   // Define some script variables
// ***** Analyze Item's Page *****
procedure AnalyzeItemPage(URL: String);   // Variable "URL" is handed over (former variable "ComicURL")
  Page, Value: string;   // Define variables "Page" and "Value"
  Page := GetPage(URL);   // Fetch source code from website and store inside "Page"
// URL import
  Setfield(fieldURL, URL);   // Save variable URL to field URL
// Picture import
  Value := '';   // Make sure "Value" is empty
  Value := TextBetween(Page, 'window.open(''', '''');   // Extract the picture URL from "Page"
  if Value = '' then   // If "Value" is still empty ( = no picture URL ) then..
    Value := 'http://www.sergiobonellieditore.it' + TextBetween(Line, '<img src="', '"');   // .. try to extract URL for small picture instead
  if Value <> '' then   // If "Value" now contains picture URL then..
    GetPicture(Value);   // .. download and save picture
// Original title import
  Value := '';
  Value := TextBetween(Page, '<table border=0 cellspacing=0 cellpadding=0>', '</table>');   // Extract title part from variable "Page"
  Value := TextBetween(Value, '<b>', '</b>');   // Extract exact title from variable "Value" now
  HTMLRemoveTags(Value);   // Clean title from HTML tags (if some exist)
  SetField(fieldOriginalTitle, Value);   // Save title to field OriginalTitle
// Beschreibung / Description
  Value := '';
  Value := TextBetween(Page, '<table width=100% cellspacing=0 cellpadding=0 border=0>', ' </td>');   // Extract description part from variable "Page"
  Value := TextBetween(Value, '<font face="Arial" size=2>', '</font>');   // Extract exact description from variable "Value" now
  HTMLDecode(Value);   // Clean description from HTML codes (if some exist)
  FullTrim(Value);   // Clean up the description
  SetField(fieldDescription, Value);   // Save description to field Description
end; // End of procedure "AnalyzeItemPage"
// ***** Beginning of the script *****
  if CheckVersion(3,5,0) then // Checks if Ant Movie Catalog version is 3.5.0 or higher
      Input('www.sergiobonellieditore.it', 'Enter comic series:', ComicSeries); // Asks for comic series number
      Input('www.sergiobonellieditore.it', 'Enter comic number:', ComicNumber); // Asks for comic item number
      ComicURL := 'http://www.sergiobonellieditore.it/auto/alborist?collana=' + ComicSeries + '&numero=' + ComicNumber + '&subnum=0'; // Build item URL
      AnalyzeItemPage(ComicURL); // Script hands over item URL and jumps to procedure AnalyzeItemPage
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.0)'); // If Checkversion fails
Everything behind the doubleslashes // is for comments only and could be deleted if not needed. It will look cleaner on AMC editor where comments are displayed green.
Thanks to both of you, I'm reallyt a newbye. The example of script given to me is very interesting and helpful.
Now I'll try to use it in my program structure.
:grinking: :hihi:
Ciao.
Dear Bad4U,
I'm using your script (easier, clearer and better than mine) and I'm trying to go on with my project.
I'd like to create an .amc database where to insert manually the minimal necessary information so that:
1) if in the fieldLabel I find the number of the Comic serie or the name of the comic serie I will not ask it
2) if in the fieldOriginalTitle i find the number of the comic, I don't ask it.
It looks easy to say but.... in writing the code my brain enters in a loop /tto much if, the, else, repeat, end etc.) and I don't succedd to write the right code:
Authors=
Description=
Language=IT
Version=v.0.1.0
Requires=3.5.0
Comments=
License=
  ComicURL, ComicSeries, ComicNumber, Collana: string;   // Define some script variables
  ctr, numCollana : integer;
  CollanaArray: Array of String;
  i, j: integer;
  Page, SavePage, Value: string;   // Define variables "Page" and "Value"
  ctr: integer;
  SavePage := Page;
// URL import
// Picture import
// Titolo tradotto
  Value := '';
  Value := StringReplace(Value, ''', '''');  // sistema gli apostofi
  SetField(fieldTranslatedTitle, Value);   // Save title to field TranslatedTitle
// Beschreibung / Description / Storia
  Value := '';
// Storia
//  showmessage (Value)
  Value := TextBetween(Value, '<font face="Arial" size=2>', 'In questo numero:');   // Extract exact description from variable "Value" now
//  Value := TextBetween(Value, '<font face="Arial" size=2>', '</font>');   // Extract exact description from variable "Value" now
// Comemnts / In questo numero
  Value := TextBetween(Value, 'In questo numero:', '</font>');   // Extract exact description from variable "Value" now
  SetField(fieldComments, ('In questo numero: ' + Value));   // Save description to field Description
  SetarrayLength(CollanaArray, 71);   // 70 elementi(collane) + elemento 0
  j := High(CollanaArray) - low(CollanaArray);
//  showmessage ('elementi ***' + Inttostr(j) + '***');
  CollanaArray[00] := 'Collana mancante';
  CollanaArray[01] := 'Tex Willer';
  CollanaArray[02] := 'Almanacco del West';
  CollanaArray[04] := 'Julia';
  CollanaArray[07] := 'Brendon';
  CollanaArray[08] := 'Dampyr';
  CollanaArray[11] := 'Napoleone';
  CollanaArray[15] := 'Nathan Never';
  CollanaArray[18] := 'Dylan Dog';
  CollanaArray[25] := 'Almanacco dell''avventura';
  CollanaArray[34] := 'Almanacco della Fantascienza';
  CollanaArray[36] := 'Almanacco della Paura';
  CollanaArray[70] := 'Almanacco del Giallo';
     collana := getfield(fieldMedia);
     numCollana := strtoint(collana, 0);
     showmessage ('collana0 ***' + collana + '***')
     showmessage ('numcollana0 ***' + inttostr(numcollana) + '***')
     if numCollana = 0 then
        if length(collana) = 0 then
           input('www.sergiobonellieditore.it', 'Enter comic series:', ComicSeries); // Asks for comic series number only 1 time
           ctr := ctr + 1;
           showmessage ('collana1 ' + collana + '***');
           collana :=  CollanaArray[i];
           numCollana := i;
           until i > j or (collana =  CollanaArray[i]);
        ComicSeries := collana;
        showmessage ('collana2 ' + collana + '***')
        SetField(fieldMedia, CollanaArray[numCollana])
//    Input('www.sergiobonellieditore.it', 'Enter comic number:', ComicNumber); // Asks for comic item number
      ComicNumber := getfield(fieldOriginalTitle);
will you help me again to escape from my coding Error?
Thanks in advance. :??:
fulvio53s03 wrote:1) if in the fieldLabel I find the number of the Comic serie or the name of the comic serie I will not ask it
      ComicSeries := GetField(fieldMedia);
      if ComicSeries = '' then
      case ComicSeries of
        'Collana mancante':     ComicSeries := '0';
        'Tex Willer':           ComicSeries := '1';
        'Almanacco del West':   ComicSeries := '2';
        'Julia':                ComicSeries := '4';
        'Brendon':              ComicSeries := '7';
This will work for either series number or series title on field Media Label, same for the input field (you can write Tex Willer or 1 there).
      ComicNumber := GetField(OriginalTitle);
      if ComicNumber = '' then
This is just one possible solution, there are many more. Just copy the code into the "clean" script instead of the two lines beginning with "Input...". You see that it does not need any new variables or even arrays for that. Keep in mind that the code is kept simple again and could be improved further, e.g. code doesn't check for correct variables or spelling errors (=script might fail in that case).
Thank you for your help.
Now I'm going better with my programmation problems and I hope to get a good point in a moment not too far.
Next step will be to speed the execution of the script and i hope you will help me again.
Do 'free' compilers exist? where can i find them?
here following the actual script:
Authors=
Title=sergiobonellieditore new.it
Description=
Language=IT
Version=v.0.1.0
Requires=3.5.0
Comments=
License=
  sw_serie : string;
  i, j: integer;
  crlf = #13#10;                        // carriage return/line feed
  Page, SavePage, Value, saveValue: string;   // Define variables "Page" and "Value"
  SavePage := Page;
// URL import
// Serie import
  Value := TextBetween(Page, '<title>Archivio arretrati: scheda dell''albo di ', '</title>');   // Extract title part from variable "Page"
  SetField(fieldMedia, Value);   // Save title to field Label
// Picture import
// Titolo tradotto
  Value := '';
//  Value := StringReplace(Value, ''', '''');  // sistema gli apostofi
// struttura dei primi numeri
  Value := '';
  saveValue := '';
// Storia
  Value := TextBetween(Page, '<table width=100% cellspacing=0 cellpadding=0 border=0>', '</DIV>');   // Extract description part from variable "Page"
//  showmessage('value1 ' + Value);
//  showmessage('value2 ' + Value);
  saveValue := Value;
// Comments / In questo numero
  Value := TextBetween(Page, '<table width=100% cellspacing=0 cellpadding=0 border=0>', ' </td>'); // Extract description part from "Page"
  if length(Value) > 0 then
// struttura dei numeri successivi (es. 214)
  if length (saveValue) = 0 then
     Value := TextBetween(page, '<DIV VALIGN=TOP>', ' </td>');   // Extract description part from variable "Page"
//     showmessage('value3 ' + Value);
     Value := TextBetween(value, '<DIV VALIGN=TOP><font face="Arial" size=2>', '</font></DIV>');   // Extract description part from variable "Page"
//     showmessage('value4 ' + Value);
     if length (Value) < 2 then   // 2 as there must be crlf
        showError ('Errore. collana ' + getfield(fieldMedia) + ' n.' + getfield(fieldOriginaltitle) + '. Trama mancante');
     saveValue := Value;
  SetField(fieldDescription, saveValue);   // Save description to field Description
//  showmessage ('descrizione ' + saveValue);
// fieldActors / Autori
  SaveValue := '';
  Value := '';
  Value := TextBetween(Page, 'Soggetto e sceneggiatura: <b>', '</b>');   // Extract part from variable "Page"
     saveValue := 'Soggetto e sceneggiatura: ' + Value + crlf;
  Value := '';
  Value := TextBetween(Page, 'Disegni e copertina: <b>', '</b>');   // Extract part from variable "Page"
     saveValue := saveValue + 'Disegni e copertina: ' + Value + crlf;
  Value := '';
  Value := TextBetween(Page, 'Disegni: <b>', '</b>');   // Extract part from variable "Page"
     saveValue := saveValue + 'Disegni: ' + Value + crlf;
  Value := '';
  Value := TextBetween(Page, 'Copertina: <b>', '</b>');   // Extract part from variable "Page"
     saveValue := saveValue + 'Copertina: ' + Value + crlf;
  SetField(fieldActors, saveValue);   // Save description to field Actors
//  SetarrayLength(CollanaArray, 71);
//                    12345678901234567890
//  CollanaArray[00] := 'Tex Willer';
//  CollanaArray[01] := 'Tex Willer';
//  CollanaArray[02] := 'Almanacco del West';
//  CollanaArray[04] := 'Julia';
//  CollanaArray[07] := 'Brendon';
//  CollanaArray[08] := 'Dampyr';
//  CollanaArray[11] := 'Napoleone';
//  CollanaArray[15] := 'Nathan Never';
//  CollanaArray[18] := 'Dylan Dog';
//  CollanaArray[25] := 'Almanacco dell''avventura';
//  CollanaArray[34] := 'Almanacco della Fantascienza';
//  CollanaArray[36] := 'Almanacco della Paura';
//  CollanaArray[70] := 'Almanacco del Giallo';
//      Input('www.sergiobonellieditore.it', 'Enter comic series:', ComicSeries); // Asks for comic series number
//      Repeat
      Repeat
      sw_serie := 'OK';
      case ComicSeries of
//      'Collana mancante':             ComicSeries := '0';
        'Tex':                          ComicSeries := '1';
        '1':  ComicSeries := '1';
        '2':  ComicSeries := '2';
        '4':  ComicSeries := '4';
        '7':  ComicSeries := '7';
        'Dampyr':                       ComicSeries := '8';
        '8':  ComicSeries := '8';
//      'Napoleone':                    ComicSeries := '11';  // http://www.sergiobonellieditore.it/auto/scheda_speciale?collana=11&numero=2&subnum=0
        'Martin Mystère':               ComicSeries := '13';
        '13': ComicSeries := '13';
        'Nathan Never':                 ComicSeries := '15';
        '15': ComicSeries := '15';
        'Dylan Dog':                    ComicSeries := '18';
        '18': ComicSeries := '18';
        'Almanacco dell''avventura':    ComicSeries := '25';
        '25': ComicSeries := '25';
        'Almanacco del Mistero':        ComicSeries := '33';
        '33': ComicSeries := '33';
        'Almanacco della Fantascienza': ComicSeries := '34';
        '34': ComicSeries := '34';
        'Almanacco della Paura':        ComicSeries := '36';
        '36': ComicSeries := '36';
        'Almanacco del Giallo':         ComicSeries := '70';
        '70': ComicSeries := '70';
         sw_serie := 'error'
      until sw_serie = 'OK';
//      ComicNumber := ComicSeries
      ComicNumber := GetField(fieldOriginalTitle);
    // If Checkversion fails end.
:up:
fulvio53s03 wrote:Next step will be to speed the execution of the script...
Don't use loops ("repeat") where it's not neccessary. I don't even understand what you are using them for, please try to explain. And your second loop will be infinite if there is no "until" to stop it.
Compilers ? For what ?
Thank you for the the time You dedicate to me.
I have only 1 'repeat' as the first 'repeat' you see is preceeded by a '//' so the 'until' is not necessary (I left some instructions related to the 'array' I used before only as documentation of my old mistakes).
Is there a metodological reason to suppress the instructions 'Repeat'?
I think it's useful but, obviousely, it could be an error!
... Compiler: I think it could give me more speed (I know that the use of Internet is surely slowly then the use of the CPU or of the use of the RAM memory) but, anyway, I was thinking that using a compiled program should be faster than using an interpreted program.
Probably I'm wrong... my ideas come from my old experience in programming DBASE III and Clipper (Summer '87).
Thanks, you are really friendly to me.
Newer version of the script engine allow to compile script for faster execution, but some work is required to include that new engine in AMC.
I never did it because I was not sure that it was really useful. Is there some speed problem with scripts currently? I think that the lowest part is the download of page/image anyway, which is done by compiled components from AMC, not really by the script itself.
Antp in right, as usual: at the moment there are non problems...
My asks come from the fact that I'm thinking to make more scripts (to avoid documentation and understanding mistakes problems), the first linking to others, to extract informations .
Maybe the problem is only mine, as I don't know exactly what happens in that case in Windows ambient (as I said, I'm used to program with old languages, in old software ambients, such as in mainframes IBM '370).
Sorry If I put too many questions!
Ciao.
About the second 'repeat' you're right, I oversaw the outcommenting. And now I understand what your intention was and even why you used the arrays on the previous script, I just was confused about that somehow.
I agree with antp, slowest part probably is download of website's data, not the execution of the script. When I open the website in browser it seems quite slow here, but I cannot test the script until tomorrow evening, sorry.
Well, I did some short tests and script doesn't seem to be slow for me compared to movie scripts. Sometimes the website might be slow, I guess.
Thank you for the time you dedicate to me.
Now I'm going on with some implementations and I have more questions, of course.
- How can I show the various opportunities I can choose to input the 'Comics Series' (among those listed in the 'case' statement, maybe I can use a 'PickList' (and how?) or other functions?) ?
- Is the HTMLdecode function comprehensive of all the possibilities of special characters I can find in an HTML page?
Thanks, more questions will follow!
ciao.
fulvio53s03 wrote:- Is the HTMLdecode function comprehensive of all the possibilities of special characters I can find in an HTML page?
No, it only handles the basic ones (&quot etc.) and the iso-8859-1 (latin1?) charset.
fulvio53s03 wrote:- How can I show the various opportunities I can choose to input the 'Comics Series' (among those listed in the 'case' statement, maybe I can use a 'PickList' (and how?) or other functions?) ?
It is possible to use PickTree for that. By default this is used to add movie titles from a results list and let the user choose the correct movie. As the site does not have search function, you could manually build such a list (series name + corresponding link) or eventually use the picture from the homepage that shows and links to all the series characters as some kind of "results list" (but then you will have to find a way to change/substitute these default links to the detail pages).
Good answer about 'picktree' but I would try an easier way: the 'input' panel.
The problem is that the panel is too short to show all my possibilities.
How can I increase the panel dimensions?
Must I use a different function?
Thanks.
