Insert certain characters from containing folder
mickah
Post by mickah »
demo1333 - movies/mymovie1.avi
I want to insert the first 8 characters of the containing folder:
demo1333-mymovie1.avi
I'm doing string insert at the moment:
%folder1%-
and getting:
demo1333 - movies-mymovie1.avi
Any ideas?
After that you can use the character deletion or string replacement to remove the "- moves" part.
mickah
Post by mickah »
the start of the folder name is always demo1333 or whatever number of 4 digit size, but what comes afterwards varies in both size and content.
So:
demo1333 - movies blah/moviename.avi
demo1259 - movies asd gah 11 blah/moviename2.avi
demo1862 - mov/moviename3.avi
are all possibilites.
All I want are the 1st 8 digits of the folder name.
you could use regular expressions to remove the part once the folder name added to file name :
expression = demo([0-9]*) - (.*)-(.*)
new name = demo$1-$3
if the original names already contain dashes, you may have to use some other character else it will keep only end of the name.
e.g.
insert: %folder1%#
and use expression: expression = demo([0-9]*) - (.*)#(.*)
mickah
Post by mickah »
that worked a treat, thank you
