Import DVD Profiler XML Missing Data
JimmyB7
Post by JimmyB7 »
When I try to import from DVD Profiler XML data appears to be missing.
Actors, Director, Producer, Country does not import. The data is in the XML file.
Other data imports OK.
I'm using DVD Profiler 3.5
Indeed Country is not taken, but the three others should be. Maybe they changed something in the format of their file. Can you send me the file by e-mail ?
It seems that they changed things since I made that importation.
Actually I made if with the XML file that a friend sent me, I do not know which version he was using. An older one I guess.
For the next release I'll try to fix that, but I do not have time right now.
