Hallo,
I've installed the Version 2.10. When I start the Ant Renamer all fields with numbers has always the default value. For example: under enumerate I set digits to 3 and mask to aaa__%num%%ext%. When I stop renamer in renamer.xml I found:
<Enum Mask="aaa_%num%%ext%" Start="1" Digits="3" Incr="1" Restart="False">
When I restart renamer the Mask is my mask but Digits is 1! Start and Incr is OK.
Under 'Char delete' the 'number of characters to delete' has the same failure.
<CharDel Nb="1"...
wr
milbes
Allways default (Version 2.10)
Milbes
Hallo,
When I wrote the first bug-report I switchted the language to 'english (default)'. Then I have to start renamer. When I switched back to my language I can do it without restart renamer.
wr
Milbes
wr
Milbes
