i can import pictures from a cvs that i exported before
ziscoyzero
Post by ziscoyzero »
i export my catalog (in cvs) with the pictures of the movies, but when i import this cvs don`t show the images (the info is correct but without images). The images are in the folder but amc don´t see them.
What i am doing wrong? :??:
Was the column with the image names assigned to "picture" field, in the csv import window?
ziscoyzero
This was the problem. I didn`t see that this column was not assigned. Now i can do it.
Thank you very very much.
