scripts for dvds only? what about vhs tapes?
antester
Post by antester »
no biggie I was just wondering if with any new version it would be possible to get scripts that take into account what form of media the film is, i.e. if it's a tape, dl the info for the tape and not the dvd info. at the moment this isn't too relevant since no DVD info is downloaded anyhow, but if something like this is planned then you might want to support VHS and DVD for automatic info downloading from various shopping sites (amazon.com/de/fr or dvdempire.com)
no other software does this so far, ANT could beat them :D
Cheers
Alex
There will be customizable fields in the next major version, but I do not know how I'll manage that through scripts.
I will try to make something that will allow what you suggest ;)
