[REL] FilmTv.it: added country and year in the picklist
Now You can see the country and the year for every movie in the picklist (multiple movies with same keywords in the title)
Authors=Fiezul (previous version: Pivello and others) & Fulvio53s03
Title=FilmTV
Site=www.Film.TV.it
Language=IT
Version=10.08.2008
Requires=3.5.0
Comments=Old script by Pivello and others didn't work due to Filmtv site complete restyling
License=The source code of the script can be used in another program only if full credits to script author and a link to Ant Movie Catalog website are given in the About box or in the documentation of the program
LargePicture=1|1|0=Get a small picture|1=Try to get the big picture
program FilmTVIt;
  //Query constants
  UrlBase = 'http://www.film.tv.it/';
  QueryBase = UrlBase + 'cerca.php?q=';
  QueryFilm = UrlBase + '';
  //Search page constants
  cStartFilmUrl = '<div class="thumb"><a href="/'; // ID start marker
  cEndFilmUrl = '"><span><img src=';           // ID end marker
  cStartTitle = 'title="';                      // Title start marker
  cEndTitle = '">';                     // Title end marker
  //Film page constants
  cStartTranslTitle = '<h1>';     // Translated title start marker
  cEndTranslTitle = '</h1>';                   // Translated title end marker
  cStartOrigTitle = '[<i>';     // Original title start marker
  cEndOrigTitle = '</i>';                   // Original title end marker
  cStartImgLink = 'title="immagini"><img src="';               // Image start marker
  cEndImgLink = '" width="166" border="0" alt="locandina"';   // Image end marker
  cStartListItem = ', ';
  cEndListItem = ', ';                        // Generic field marker
  cStartDirectors = 'Regia di';               // Director start marker
  cEndDirectors = '<br />';                         // Directors end marker
  cStartDirector = '">';               // Single Director start marker
  cEndDirector = '</a>';                         // Single Director end marker
  cStartCast = 'Con ';                   // Cast start marker
  cEndCast = '</div>';                   // Cast end marker
  cStartActor = '">';                      // Actor start marker
  cEndActor = '</a>';                      // Actor end marker
  cStartDesc = '<p class="trama">';              // Description start marker
  cStartComm = '<p class="commento">';           // Comment start marker
  cEndComm = '</p>';                         // Comment end marker
  cStartURL='<li id="sel"><a href="/';
  cEndURL='" title="scheda"';
  InitYear = '<span>';
  EndYear = '</span>';
  searchUrl,MovieUrl, MovieName, OriginalStr, TranslatedStr, PageStr:  string;
// PAGE PACKING (remove extra spaces, tabs & CR) by Pivello
// IN:  page Url     (string)
// OUT: compact page (string)
  TmpPageStr: string;
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  TmpPageStr := '';
  Page.Text := GetPage(Url);
  for n := 0 to Page.Count - 1 do
    if CharPos = 0 then
    if CharPos <> 0 then
        Temp := copy(PackedPage, 1, CharPos - 1);
  result := PackedPage;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure SetMovieFields (htmlStr: string);
  i, h, m: integer;
  Duration, Description, Cast, TempStr, TempImg, hh, mm,temp: string;
  tempDirector, director:string;
  imageLink: string;
  sep1,sep2: string;
  // General movie description fields
  SetField(fieldTranslatedTitle, getTextDelimited(cStartTranslTitle, cEndTranslTitle,htmlStr));
  SetField(fieldOriginalTitle, getTextDelimited(cStartOrigTitle, cEndOrigTitle,htmlStr));
  if GetField(fieldOriginalTitle)='' then
    sep1:='['
    sep1:= cStartListItem;
  SetField(fieldCountry, getTextDelimited(sep1, cEndListItem,htmlStr));
  SetField(fieldYear, getTextDelimited(cStartListItem, cEndListItem,htmlStr));
  SetField(fieldCategory, getTextDelimited(cStartListItem, cEndListItem,htmlStr));
  SetField(fieldLength, getTextDelimited(cStartListItem + 'durata ', ''']',htmlStr));
  //Get director
  temp:= getTextDelimited(cStartDirectors, cEndDirectors,htmlStr);
  SetField(fieldDirector, getCSVField(cStartDirector,cEndDirector,temp));
  //Get actors
  temp:= getTextDelimited(cStartCast,cEndCast ,htmlStr);
  SetField(fieldActors, getCSVField(cStartActor,cEndActor,temp));
  //Get URL
  SetField(fieldURL, URLBase + getTextDelimited(cStartURL, cEndURL,htmlStr));
  //Get image
  imageLink:= getTextDelimited(cStartImgLink,cEndImgLink,htmlStr);
  GetPicture(imageLink);
  //Get comments
  SetField(fieldDescription, getTextDelimited(cStartDesc,cEndDesc ,htmlStr));
  SetField(fieldComments, getTextDelimited(cStartComm,cEndComm ,htmlStr));
//Returns a CSV list from an input string strIn where list items are
//separated by delIn and delOut strings
function getCSVField (delIn:string; delOut: string; Var strIn: string): string;
  tempOut: string;
  result:='';
    tempOut:=getTextDelimited(delIn, delOut,strIn);
    if tempOut<>'' then
      result:=result + tempOut + cStartListItem;
  until tempOut='';
  if length(result)>0 then result:=copy(result,1,1+length(result)-3);
//Returns a text field from an input string strIn
//delIn and delOut: text field delimiters
function getTextDelimited(lIn:string; lOut:string;Var strIn:string): string;
  StartPos: integer;
  len:integer;
  tempStr: string;
  StartPos := pos(lIn, strIn);
  if startPos<>0 then
    StartPos:=StartPos+Length(lIn);
    tempStr:= copy(strIn,StartPos,StartPos+length(strIn));
    len := pos(lOut, tempStr);
     if len=0 then
      result:=''
      result := copy(strIn, StartPos, len-1); // get Text Out
  Delete(strIn, 1, StartPos-1 + len-1 + length(lOut)-2);
    result := '';
  HTMLDecode(result);
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
procedure PopulatePickTree();
  filmUrl, partialUrl: string;
  filmTitle, filmYear: string;
  StartPos: integer;
  EndPos: integer;
        partialUrl:= getTextDelimited(cStartFilmUrl,cEndFilmUrl,PageStr);
        filmUrl:=UrlBase + partialUrl;
        filmTitle:=getTextDelimited(cStartTitle,cEndTitle,PageStr);
//      ShowMessage ('Titolo ***' + filmTitle + '***');
        filmYear:=getTextDelimited(InitYear, EndYear,PageStr);
//      ShowMessage ('Year ***' + filmYear + '***');
        filmTitle := filmtitle + ' ' + filmYear;
        if partialUrl<>'' then
          PickTreeAdd(filmTitle, filmUrl);
      until(partialUrl='');
// IN:  html of search page (string)
// OUT: movie url
function getMovieUrl(htmlSearchPage: string): string;
  FilmId: string;
  result:='';
  if pos('Non ho trovato nulla!', htmlSearchPage) > 0 then
      PopulatePickTree();
      if not PickTreeExec(result) then exit; //Select one title
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,5,0) then
      if (TranslatedStr <> '') then
        MovieName := TranslatedStr
        MovieName := OriginalStr;
      if(Input('Film.TV.It', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
          //Get search page
          searchUrl := QueryBase + UrlEncode(MovieName);
          PageStr := RemoveExtraChars(searchUrl);
          //Analyze search page and get movie url (user choice)
          MovieUrl:=getMovieUrl(PageStr);
          // Get movie page
          //Analyze movie page and set movie fields
          SetMovieFields(PageStr);
Suggestions are well accepted.
Thanks.
LucMa
Post by LucMa »
thank's but for me it have always the same problem :cry:
Sorry but I don't understand: which is "the same problem" you're saying?
bye.
