[REL] Update FilmUP.it: added year of the Movie in Picklist
After a long while, I got the solution I was looking for and I show the year of every movie listed in the picklist.
Instructions added are between the marks 'Fulvio53s03'
Please notify me for errore.
By.
Thanks. I added the "code" tags, but even with that the ident of the code is not there, I guess you copied it from the other topic where you posted it by mistake?
As I already removed the code from the "wrong" topic, can you edit the post to re-paste it with the indent (i.e. direct copy from the script itself) ;)
Dear Antoine, you are right, as usual!
Let's try:
Code:
Authors=L. Francisco
Title=FilmUP
Description=Get movie info from LeoFilmUP.it and shows years il picklist (Fulvio53s03)
Site=http://filmup.leonardo.it
Language=IT
Version=1.0.2 - 16.09.2005
Requires=3.5.0
Comments=**Changes**|Pivello: query URL changed|Zandal:  sistemato puntamento a COMMENTS|Pivello: Film site URL selectable instead of FilmUp page URL|dinolib: adapted to v.3.5.0 and little bugfix | ABNormal restarted...|14.04.2005: Fixed infinite loop if description field missing (Pivello)|16.09.2005: Look for new Main Actors data into page; if present select this instead of Cast data (P)|16.09.2005: Added ActorPlusCast option (P)|03.10.2005 ABNormal: Big Posters and Comments again|14.01.2006 ABNormal: Trailer URL
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script author and a link to Ant Movie Catalog  |*  website are given in the About box or in       |*  the documentation of the program               |
AlternateURL=0|0|0=Use the FilmUP web site for FieldURL|1=Try to use ufficial movie web site for FieldURL
MezzoVoto=1|1|0=Integer Ratings|1=Ratings with ,5
ActorsPlusCast=0|0|0=Get Main Actors data (if present) otherwise get Cast field|1=Get Main Actors data (if present) and Cast data
TrailerURL=0|0|0=Normal URL page|1=Trailer URL page (if found)
program LeonardoFilmUP;
  StringUtils1;
  TheMovieAddress: string;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  LineNr := FindLine('Ordina risultati per', Page, 0);
  if LineNr = -1 then
    AnalyzeMoviePage(Page);
    AddMoviesTitles(Page);
    if TheMovieAddress='' then
      if PickTreeExec(Address) then AnalyzePage(Address);
  Line, PreviousLine, NomeHtml, sTemp: string;
  LineNr,PrevLineNr, BeginPos, EndPos, Field: Integer;
  IsMainActors: boolean;
  IsMainActors := false;
  sTemp := '';
  LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
  if LineNr > -1 then
    //Translated Title
    HTMLRemoveTags(Line);
      //Look for next info
        LineNr := LineNr + 1;
      until (Line<>'')  or (LineNr > Page.Count);
      // Test if 'Trama:' missing
      if ((PreviousLine = 'Data di uscita: ')
      or  (PreviousLine = 'Uscita prevista: ')) and (Line <> 'Trama:') then
        if (copy(Line,1,6)<>'Trama:') then
          Line := 'Trama:' + Line;
      PreviousLine := Line;
      //Look for type of line
      if Line = 'Titolo originale: ' then
        Field := fieldOriginalTitle
      else if Line = 'Regia: ' then
        Field := fieldDirector
      else if Line = 'Produzione: ' then
        Field := fieldProducer
      else if Line = 'Nazione: ' then
        Field := fieldCountry
      else if Line = 'Genere: ' then
        Field := fieldCategory
      else if Line = 'Anno: ' then
        Field := fieldYear
      else if Line = 'Durata: ' then
        Field := fieldLength //Special case: get number only
      else if Line = 'Sito ufficiale: ' then
        Field := fieldURL
      else if Line = 'Attori protagonisti: ' then
        Field := fieldActors;
        IsMainActors := true;
      else if Line = 'Cast: ' then
      else if Line = 'Trama:' then
        Field := fieldDescription
        Field := 0;
      // I have to add this test, for sometimes the description
      // is on the same line as the tag 'Trama'
      if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
        Field := fieldDescription;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
        //Special case: Length
        if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
       //Alternative URL case
       if (field = fieldURL) then
         if (Length(Line) = 0) or (GetOption('AlternateURL')=0) then      // if WEB url missing or explicitly requested...
           Line := GetField(fieldURL)  // ...restore FilmUp URL
           Line := 'http://'+Line;
      if Field<>0 then
       if Field = fieldActors then
         if IsMainActors then // Remember Main Actors (if present)
           sTemp := Line;
           if ((GetOption('ActorsPlusCast')=1) and (sTemp<>'')) then
             Line := sTemp + ' Cast: ' + Line
             if sTemp <> '' then
               Line := sTemp;
           SetField(Field,Line);
    until (Field=fieldDescription) or (LineNr > Page.Count);
  PrevLineNr := LineNr;
   //Trailer
if GetOption('TrailerURL')=1 then begin
LineNr := FindLine('">Trailer</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('size="2"><a', Line) <> 0 then Delete(Line,1,pos('size="2"><a',Line));
    //if Pos('DVD', Line) <> 0 then Delete(Line,1,pos('DVD',Line));
    Delete(Line,1,pos('href="',Line)+5);
    NomeHtml := Copy(Line,1,pos('"',Line)-1);
    if (copy(NomeHtml,1,1)<>'/') then
      NomeHtml := '/' + NomeHtml;
NomeHtml :='http://filmup.leonardo.it' + NomeHtml;
    comm := textbetween(GetPage(NomeHtml),'<EMBED SRC="','"');
//HTMLRemoveTags(comm);
SetField(fieldURL,comm);
  //Comments
  LineNr := FindLine('">Recensione</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('Scheda', Line) <> 0 then Delete(Line,1,pos('Scheda',Line));
    NomeHtml :=Copy(Line,1,pos('"',Line)-1);
comm := textbetween(GetPage(NomeHtml),'<font face="arial,helvetica" size="2"><b>','<a class="filmup" href="opinioni.htm">');
comm := textafter(comm,'</b><br>'+#13#10);
SetField(fieldComments,comm);
  //Rating
  LineNr := FindLine('">Opinioni</a>', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('Recensione',Line));
    Line := GetLineFromOtherPage(Copy(Line,1,pos('"',Line)-1),'</b> - <img src="');
    if Line <> '' then
      Line := Copy(Line,1,pos('</b> - <img src="',Line)-1);
      if GetOption('MezzoVoto')=0 then
 if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
      SetField(fieldRating,Line);
  //Picture
    LineNr := FindLine('<img src="locand', Page, PrevLineNr);
    if LineNr > -1 then
      Delete(Line,1,pos('<img src="locand', Line)+9);
      GetPicture('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1));
  LineNr := FindLine('href="posters/locp/', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('href="posters/locp/',Line)+5);
    Line := GetLineFromOtherPage('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
    if Line <> '' then
      Delete(Line,1,pos('<img src="../',Line)+12);
      GetPicture('http://filmup.leonardo.it/posters/'+Copy(Line,1,pos('"',Line)-1));
  //DisplayResults;
function GetLineFromOtherPage(address: string; hint: string): string;
  LineNr: integer;
  LineNr := FindLine(hint, Page, 0);
  if LineNr > -1 then result := Page.GetString(LineNr);
procedure GetComments(address: string);
  BeginLine: integer;
  EndLine: integer;
  i: integer;
  Line, Comments: string;
  BeginLine := FindLine('RECENSIONI', Page, 0);
  BeginLine := FindLine('<font face="arial,helvetica" size="2"><b>', Page, BeginLine);
  EndLine := FindLine('<a href="opinioni.htm">Scrivi la tua recensione!</a></font><br><br>', Page, BeginLine);
  for i:= BeginLine+1 to EndLine-1 do
    Line := Page.GetString(i);
    Line := StringReplace(Line, '<br>', #13#10);
    Line := StringReplace(Line, #13#10#32, #13#10);
    HTMLDecode(Line);
    Comments := Comments + Line;
  MovieTitle, MovieAddress, MovieAnno: string;
  BeginPos, EndPos: Integer;
  LineNr := 0;
  LineNr := FindLine('FilmUP - Scheda: ',Page,LineNr);
while LineNr > -1 do
  MovieAddress := 'http://filmup.leonardo.it/sc_' + TextBetween((Page.GetString(LineNr-1)), '_', '.') + '.htm';
  MovieTitle := TextAfter(Page.GetString(LineNr), 'Scheda: ');
      While pos ('<span', MovieTitle) > 0 Do begin
      MovieTitle := TextBefore(MovieTitle, '<span', '') + TextAfter(MovieTitle, 'bold;">');
      While pos ('</span', MovieTitle) > 0 Do begin
      MovieTitle := TextBefore(MovieTitle, '</span', '') + TextAfter(MovieTitle, '/span>');
// Inizio Fulvio53s03
  LineNr := FindLine('Anno: ',Page,LineNr);
//  Showmessage ('Line ***' + Line + '***')
  MovieAnno := TextAfter(Page.GetString(LineNr), 'Anno: ');
  Showmessage ('MovieAnno ***' + MovieAnno + '***')
      If pos ('Anno: ', Line) > 0 then
      begin;
      MovieAnno := TextBefore(MovieAnno, ' Genere: ', '') + TextAfter(MovieAnno, 'Anno: ');
//    showmessage ('Anno***' + MovieAnno + '***');
      MovieAnno := '    ';
// Fine   Fulvio53s03
    HTMLRemoveTags(MovieTitle);
    HTMLDecode(Movietitle);
    LineNr := FindLine('FilmUP - Scheda:',Page,LineNr+1);
    MovieTitle := MovieTitle + ' [' + MovieAnno + ']';
    if TheMovieAddress='*' then
      TheMovieAddress := MovieAddress
      TheMovieAddress := '';
  LineNr := FindLine('Successivo',Page,LineNr);
  BeginPos := pos('HREF',Line);
  if BeginPos>0 then
    Delete(Line,1,BeginPos + 5);
    EndPos := pos('"',Line);
    MovieAddress := copy(Line,1,EndPos-1);
    PickTreeMoreLink(MovieAddress);
// Questo è il main dello script
  if CheckVersion(3,5,0) then
    TheMovieAddress := '*';
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
    if Input('FilmUP Import', 'Digita il titolo del film:', MovieName) then
      AnalyzePage('http://filmup.leonardo.it/cgi-bin/search.cgi?q='+UrlEncode(MovieName)+'&ul=%25%2Fsc_%25');
    ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.5.0)');
Bye.
Sorry, there's something wrong in my computer. Even using copy/paste of block notes I don't get the exact ident of the script.... I'm confused....
you did not use the
 tag ;) I added it and removed code from first message then
Where and how may I introduce the tag code?
maybe I must write exactly:
and not simply    code
at the beginning of the script? Thanks.
put [code] before the 1st line fo the script and [/code] after the last line ;)
(written like that, with the brackets)
You can also see it added in your message if you click the "edit" icon of it (pencil icon on the right of your message)
lucamark
Post by lucamark »
Just a little question...
it's right to show a msgbox (with the Year,category,etc) when i search a movie or is a line that should to be comment???
Tia!!!
:??: show at what moment in the script? I do not really see why
lucamark
Post by lucamark »
when i search the movie title and before the PickTreeAdd function...
maybe this?
at line 310 of the script (using script editor...)
I'm confused :hum: , only for me???
Sorry I thought that you wanted to add it, I did not understand that you asked about a line already in the script.
I guess that this line was there for testing: for normal use of the script it should commented I guess, with a // in front of it then.
lucamark
Post by lucamark »
i'm sorry, my english is not so good!!! :( :( :(
Here is the modified script...
Title=FilmUP
Language=IT
Version=1.0.3 - 19.09.2005
Requires=3.5.0
Comments=**Changes**|Pivello: query URL changed|Zandal:  sistemato puntamento a COMMENTS|Pivello: Film site URL selectable instead of FilmUp page URL|dinolib: adapted to v.3.5.0 and little bugfix | ABNormal restarted...|14.04.2005: Fixed infinite loop if description field missing (Pivello)|16.09.2005: Look for new Main Actors data into page; if present select this instead of Cast data (P)|16.09.2005: Added ActorPlusCast option (P)|03.10.2005 ABNormal: Big Posters and Comments again|14.01.2006 ABNormal: Trailer URL|16.09.2008 Fulvio53s03: shows years il picklist|19.09.2008 Gigibop: Comment ShowMessage (debug pourpose...)
  StringUtils1;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  if LineNr = -1 then
  sTemp := '';
  if LineNr > -1 then
    //Translated Title
        Field := fieldYear
        Field := fieldURL
        Field := 0;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
      if Field<>0 then
           sTemp := Line;
             if sTemp <> '' then
               Line := sTemp;
   //Trailer
  if LineNr > -1 then
  //Comments
  if LineNr > -1 then
  //Rating
  if LineNr > -1 then
    if Line <> '' then
  //Picture
    if LineNr > -1 then
  if LineNr > -1 then
    if Line <> '' then
  //DisplayResults;
  LineNr: integer;
  BeginLine: integer;
  EndLine: integer;
  i: integer;
    HTMLDecode(Line);
  LineNr := 0;
//  Showmessage ('MovieAnno ***' + MovieAnno + '***')
      begin;
      MovieAnno := '    ';
// Fine   Fulvio53s03
  if BeginPos>0 then
:grinking:
Well done!
Sorry for my mistakes, I forgot some control statement! :hihi:
fmsgorb
add Poster flag feature
Post by fmsgorb »
I have just add a flag to give to user the choice of choose the downloaded poster size
Add the Option "Poster"
= 0 => Download tiny Poster
= 1 => Download full-res Poster
line 23
Poster=1|0|1=Download full-res Poster|0=Download tiny Poster
line 255 or 256
  // start fmsgorb Code
  if GetOption('Poster')=1 then
    if LineNr > -1 then
      if Line <> '' then
  // end fmsgorb Code
[/code]
Well done!
.... but you know.... Italians do it better! :grinking:
jokes apart, I think it would be better if you publish complete managed script.
I checked the script using the title 'Pelham' and it looks to always extract the full-size image (but the error could be mine.....)
Thanks!
Splendido, ma si sa..... Italians do it better! (meglio non tradurre....).
Schersi a parte, credo sarebbe meglio se si pubblicasse l'intero script che, provato col titolo 'Pelham', sembra funzionare ma estrae sempre e solo l'immagine ingrandita (ma può essere un mio errore....)
Grazie!
fmsgorb
Post by fmsgorb »
yessssah
italians do it better! :grinking:
here the complete script ;)
Authors=L. Francisco, Pivello, Zandal, Fulvio53s03, ...
Title=FilmUP
Language=IT
Version=1.0.4 - 12.09.2008
Requires=3.5.0
Comments=**Changes**|Fulvio53s03: shows years in picklist|Pivello: query URL changed|Zandal:  sistemato puntamento a COMMENTS|Pivello: Film site URL selectable instead of FilmUp page URL|dinolib: adapted to v.3.5.0 and little bugfix | ABNormal restarted...|14.04.2005: Fixed infinite loop if description field missing (Pivello)|16.09.2005: Look for new Main Actors data into page; if present select this instead of Cast data (P)|16.09.2005: Added ActorPlusCast option (P)|03.10.2005 ABNormal: Big Posters and Comments again|14.01.2006 ABNormal: Trailer URL
Poster=0|0|1=Download full-res Poster|0=Download tiny Poster
  StringUtils1;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  if LineNr = -1 then
  sTemp := '';
  if LineNr > -1 then
    //Translated Title
        Field := fieldYear
        Field := fieldURL
        Field := 0;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
      if Field<>0 then
           sTemp := Line;
             if sTemp <> '' then
               Line := sTemp;
   //Trailer
  if LineNr > -1 then
  //Comments
  if LineNr > -1 then
  //Rating
  if LineNr > -1 then
    if Line <> '' then
  //Picture
    if LineNr > -1 then
    if LineNr > -1 then
      if Line <> '' then
  // end fmsgorb Code
  // DisplayResults;
  LineNr: integer;
  BeginLine: integer;
  EndLine: integer;
  i: integer;
    HTMLDecode(Line);
  LineNr := 0;
      begin;
      MovieAnno := '    ';
// Fine   Fulvio53s03
  if BeginPos>0 then
Thanks, updated on the server.
At the same time I increased the version number to 1.0.5
Full script is not mandatory when there are only minor changes - once it is updated on the server I guess that most of the users will get it from there.
DjDiabolik
Post by DjDiabolik »
The latest 1.0.5 have a wrong update date in the file:
Title=FilmUP
Language=IT
Version=1.0.5 - 04.11.2008
Requires=3.5.0
And whit this latest version it's no more possibibly to pick the zoomed image of a cover........ the latest pick only a small cover......
Indeed I forgot to change the year :D
And for the other thing, you mean that the new option to get large posters does not work when you set it to 1?
DjDiabolik
antp wrote:Indeed I forgot to change the year :D
mmmmm... how i can found this newest option ?
