Editing fields
Lucio
Editing fields
Post by Lucio »
Hi community
I have the 3.5.1.2 version of Ant Movie Catalog, and i want to edit some fields (change the word "Producer" for "screenwriter" for example). But i don't know how.
Somebody can help me?
Thanks!
Re: Editing fields
For this specific case, you can upgrade to the latest version as it has a Writer field :)
If you want to stick to that old version you can change the labels.
If you use the program in English, be sure to switch to "English for translations" in Tools -> Language.
Then go in the "Languages" subfolders where you installed the program, e.g. c:\program files\Ant Movie Catalog or c:\program files (x86)\Ant Movie Catalog, and open in Notepad the .lng file matching the language that you use.
In that file, search for [TMovieFrame]
Just under that list you fill find the translation texts used for each field. Change only the part on the right of the "=" signs.
