Add comment in help file on UTF-8 format for ARB files
hektor_paris
Post by hektor_paris »
Hello,
Many thanks for this great application.
I have a comment on the help file concerning the command line chapter:
It would be useful to precise that the ARB files have to be saved in UTF-8 format (and not ASCII for example).
I'm french and manipulate lots of file with accent in the names ("é", "à", ...). I have faced many problems til I find one of your response in the forum which indicates the UTF-8 format for ARB and jobs files. But finding this comment is not easy...
And of course, I don't encounter any problem more with command line jobs.
Bien à toi.
Régis
Re: Add comment in help file on UTF-8 format for ARB files
If you create a file with the program as sample/test file and then complete it, it is normally already correctly encoded (and has a XML UTF8 prologue), so it is probably easier as starting point than creating a file from scratch.
