add script
sanzo77
add script
Post by sanzo77 »
Hi i'm italian, i want to add the script that i can find in the script section, but i can't know how. May you help me?
thx :grinking:
I guess you are talking about one of the new italian scripts here on the forum, are you ?
You have to copy the complete script (that's what is on this code box)
and paste it into a new, empty file. For that you can use any standard texteditor like Windows notepad, then save this script to your Ant Movie Catalog scripts folder with a filename like wuz.ifs or SediciFilm.ifs - you just need to care for the .ifs extension, so that AMC can find the file. Run the script..
Or you can wait until the new script is downloadable from http://update.antp.be/amc/scripts/ or via script UPDATE_SCRIPTS.
Normally all scripts posted on the forum are added there within 24 or 48h. If you notice one still missing do not hesitate to mention it, I may have missed it.
