I am looking to rename my "program files," "windows," and "documents and settings" folders from a boot cd so I have no conflicts during a windows re installation...
will livexp and ant renamer work?
thanks guys.
ty
Ant Renamer + WinBuilder on renaming the Windows folder
ravenise
ravenise
I see. Thank you for your speedy reply antp. Do you have any idea if renaming these protected folders from a linux boot cd will be simple and native to LiveXP, VistaPE, nativeEx, React Os..etc? Will built in xp user permissions burden such a transaction?antp wrote:Ant Renamer will just change the name like if you do it manually. It is rather for handling large amount of files, in this case I do not think it would really be useful.
Thanks! tyler
