As usual, i've tested with a few movie, so if you find bug/errors let me know!!
Authors=Gigibop (luca.marcato@gmail.com)
Title=SediciFilm
Description=Get movie info from http://www.sedicifilm.it
Site=http://www.sedicifilm.it
Language=IT
Version=1.0 - 28.08.2008
Requires=3.5.0
Comments=Changes|28.08.2008 v. 1.0.0: First version (Gigibop)||
program SediciFilm;
  StringUtils1;
  TheMovieAddress: string;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  LineNr := FindLine('<br><h2>Film</h2><br>', Page, 0);
  if LineNr = -1 then
    AnalyzeMoviePage(Page);
    AddMoviesTitles(Page);
    if TheMovieAddress='' then
      if PickTreeExec(Address) then AnalyzePage(Address);
function RemoveTabs(Pattern: string): string;
  Delete(Pattern, 1, 1);
  until ord(copy(Pattern, 1, 1)) <> 9;
  result := Pattern;
function TranslateSpecial(str1: string) :string;
	str1 := StringReplace(str1, '&', '&');
	HTMLDecode(str1);
	result := Trim(str1);
  Line, PreviousLine, NomeHtml, Actors,Category, sTemp: string;
  LineNr,PrevLineNr, BeginPos, EndPos, Field: Integer;
  BeginLine: integer;
  EndLine: integer;
  i: integer;
  Languages: string;
  IsMainActors: boolean;
  IsMainActors := false;
  sTemp := '';
  //	cerco il titolo tradotto e il titolo originale
  LineNr := FindLine('<div class="boxhome">', Page, 0);
  if LineNr > -1 then
    //Titolo tradotto
    LineNr:= LineNr + 1;
    Line := RemoveTabs(Line);
    HTMLRemoveTags(Line);
    Line := TranslateSpecial(Line);
    Line := AnsiLowerCase(Line);
    Line := AnsiUpFirstLetter(Line);
    SetField(fieldOriginalTitle, Line);
  //Regia
  LineNr := FindLine('<b>Regia:', Page, 0);
  if LineNr > -1 then
      SetField(fieldDirector,Line);
  LineNr := 0;
  //    Cast
  LineNr := FindLine('<b>Cast:', Page, 0);
  if LineNr > -1 then
      SetField(fieldActors,Line);
  LineNr := 0;
  //    Genere
  LineNr := FindLine('<b>Genere:', Page, 0);
  if LineNr > -1 then
      SetField(fieldCategory,Line);
  LineNr := 0;
  //  anno di uscita
  LineNr := FindLine('<b>Anno:', Page, 0);
  if LineNr > -1 then
      SetField(fieldYear,Line);
  LineNr := 0;
  //  durata
  LineNr := FindLine('<b>Durata:', Page, 0);
  if LineNr > -1 then
      Line := StringReplace(Line, '''', ' ');
      SetField(fieldLength,Line);
  // descrizione
  Languages := '';
  LineNr := FindLine('<b>Trama:', Page, 0);
  if LineNr > -1 then
    BeginLine := LineNr + 1;
    EndLine := FindLine('<b>Genere:', Page, BeginLine) -1 ;
    for i:= BeginLine+1 to EndLine-1 do
      Line := Page.GetString(i);
      Line := Copy(Line,2,Length(Line));
      Languages := Languages + ' ' + Line;
    Languages := Trim(Languages);
    SetField(fieldDescription, Languages);
  //  locandina del film
  LineNr := FindLine('img alt="LOCANDINA:', Page, 0);
  if LineNr > -1 then
    Line := TextAfter(Line, 'src="');
    Line := TextBefore(Line, '">','');
    GetPicture(Line);
  LineNr,EndLine: Integer;
  BeginPos, EndPos: Integer;
  LineNr := 0;
  LineNr := FindLine('<tr><td align=''left'' class=corpo colspan=2>',Page,LineNr);
  EndLine := FindLine('<br><h2>Videogiochi</h2><br>',Page,0);
  if EndLine = -1 then EndLine := 999999;
while ((LineNr > -1) and (LineNr <= EndLine)) do
    MovieAddress := 'http://www.sedicifilm.it/scheda_dvd.php/' + TextBetween(Line, 'scheda_dvd.php/', '/''>') ;
    MovieTitle := Line;
    HTMLDecode(Movietitle);
    Movietitle := AnsiLowerCase(Movietitle);
    Movietitle := AnsiUpFirstLetter(Movietitle);
    LineNr := FindLine('<tr><td align=''left'' class=corpo colspan=2>',Page,LineNr+1);
    if TheMovieAddress='*' then
      TheMovieAddress := MovieAddress
      TheMovieAddress := '';
  LineNr := FindLine('?page=1&genere=',Page,LineNr);
  BeginPos := pos('href=',Line);
  if BeginPos>0 then
    Line := TextBetween(Line, 'a href=''', '>');
    Line := Copy(Line,1,Length(Line) -1);
    MovieAddress := 'http://www.sedicifilm.it/catalogo.php' + Line;
    //Delete(Line,1,BeginPos + 5);
    //EndPos := pos('"',Line);
    //MovieAddress := copy(Line,1,EndPos-1);
    PickTreeMoreLink(MovieAddress);
// Main Script
  if CheckVersion(3,5,0) then
    TheMovieAddress := '*';
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
    if Input('SediciFilm Importazione Film', 'Digitare il titolo del film:', MovieName) then
      AnalyzePage('http://www.sedicifilm.it/catalogo.php?cat=&q='+UrlEncode(MovieName));
    ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.5.0)');
