Extension for MCE
A Poll? Good idea! XD. Are you agree with me about MCE extension?
yes
1
100%
no
0
No votes
It is imposible
0
No votes
Total votes: 1
tachenco
Extension for MCE
Post by tachenco »
Have you think about make an extension for Windows Media Center?, could be a great idea!
Now i have an HTPC i've discovered software like "My movies" which works with MCE and is similar to Ant Movie Catalog.
Thought for me AMC is much better, propably at the end i will pass all my movies to software like My Movies, only because of the MCE extension... :(
Regards
tachenco
Re: Extension for MCE
Post by tachenco »
tachenco wrote:Have you think about make an extension for Windows Media Center?, could be a great idea!
Regards
PD: Other option is make an script to export data to My Movies, for example, i don't know...
I do not know what "MyMovies" needs as data format, but it should be possible to convert data.
I do not have time to make an extension for MCE, but anybody is free to do it :D
