Printing large amount of pages Error occurs
klepptoman
Post by klepptoman »
I keep getting a error msg
"an error occurred during calculating"
[picture]
Report: frreport1
Band: Master data
It only occurs with large prints 200+ pages :cry:
That's annoying... as I can't really help :/
I guess that it handles badly the images in such big reports, but as that reporting code is not done by me I can't really check that easily.
Does it work if you try to print separately the list, i.e. split in groups.
Else maybe it is just one of the images which is corrupted or not liked by the reporting engine.
klepptoman
I can split it into groups of 1000 & it works, & I did have a bad jpg file I found, but even after replacing that it still occurs.
BTW I am trying this on a Dual core pc with 4 gigs of ram & AMC is the only program running! :hihi:
hms
Post by hms »
Is the reporter running out of memory or what? I can only make names only reports, because the list is too long. Grouping them sounds annoying, any chance for updated reporter?
As I said, it is not me who made that reporting.
It seemed to work with long reports but if you have big pictures I guess it may encounter problems.
No update is planned on short term anyway.
